Suspension & Spring
biao
348
24
perak / ipoh
Dear All Sifu,
i planning to change my existing Absorber due wear & tear worm out.
Ah Wah suggest me front use EVO, rear use Airtrek.
may i know if both front & rear also use EVO, can? EVO X suitable ?
And anyone know ACE SUSPENSION this brand at Seremban? is custom make absorber same like TITAN SUSPENSION.
The boss suggest me change adjustable suspension, as he say the spring rate and suspension can custom tune. can tune to comfort and stable, compare with original. is it true? because as i know adjustable suspension is no comfort.
any sifu can advise me your opinion.
thanks
Dear All Sifu,
thanks
If he can tune, yes can be done, but he needs different spring rate to do it.....:driver:
sweelt
Nov 6, 2016
2,306
248
As i read many adjustable/coilover thread. Cant expect 100% comfort like stock.
And again i wish i join ZTH earlier...hahahaha. Anyway, lesson learn on coilover. :bawling:
Aim for spring rate, like uncle VR mention. The rest, got many choices of shocks. Twintube, monotube, inverted...etc. You driving EVO ?
kurt_629
872
54
johor
actually if you wanna save money, what you can actually do.
Find a decent adjustable, probably cost your rm1k?
either request for 8k 4k setup or 6k 4k set up.
I'm currently using 8k 4k, using DD adjustable.
stability and handling is there.
comfort, of course, not as good as stock but still ok..
biao
348
24
perak / ipoh
i'm driving Airtrek
biao
348
24
perak / ipoh
like your set-up, can carry how many passenger?
kurt_629
872
54
johor
ermm, plus myself is 4pax.
using 225/45/17
front 8k, rear 4k
around 1 finger for front, 2 for rear.
with stuff and spare tyre..
ok, no rubbing or whatsoever
if got chance, I actually looking for 6k 300mm tall
Airtrek, 8k/4k should be ok. Consider the weight.
actually its still too firm...
on my similar car (scooby version of airtrek)...im using 7k front, 5k rear...still i found out that front is still a little bit on hard side...i would say 6k,4k would be perfect for airtrek...and my car :driver:
and biao....what colour is your trek? i think i saw several turbo trek in seremban.... :biggrin:
biao
348
24
perak / ipoh
using 225/45/17
front 8k, rear 4k
drive on the highway will bumping or not? or cross the bump will crack the bottom frame?
biao
348
24
perak / ipoh
black color
Yah 8k/4k setup seems too stiff at the front relative to the rear/too much difference between front & rear, hence should make it even more understeer.
WTA, which combination of absorbers and sport springs would be best for street use? i know most of u would change to adjustables, but IMO i think that it wud be too hard for regular everyday use.
opinions?
:adore:
