Need advice on brake kit
Currently I'm using 96 DC2R master cylinder.. Is that good enough or it'd be best to upgrade? And if i am upgrading, any recommended Master cyclinder?
You can try them out first. If not good then only change.....:driver:
tonyparir
49
508
Finally got my hands on these bad boys.. albeit pricey for what it is.
Don't have any more photos, this was post washing photos, sadly I'm not into photography and not good at it, else there would be more photos.
Next would be steel braided and pmu 282 rotors
mADmAN
1,840
547
curious... why PMU rotors and which versions? some have said that the 1 piece are pretty much a waste of money. better to buy brand new solid rotors and use that instead. RM400 can get u a pair for H22A 282mm rotors...will need to redrill PCD if ur not on PCD114.3*4
if ur getting the 2pcs rotors, then by all means.. go ahead.
tonyparir
49
508
PMU rotors cause it's available at one of the shop in Sunway lol.. and pricing wise at 1170 should be okay la.. The normal SCR version (1 piece)... Errmm I asked around, so far no negative feedback on the PMU disc... But since you said it's a waste of money.. I'm quite taken aback lol.. One of my friend told me instead of getting PMU i'd better be getting endless rotors, but he did not tell me why too lol.. He just said it's proven, but endless seems to be out of my budget (i might be wrong though haha)
2 piece rotors would be way out of my budget.. Planning to save that extra money for a hondata or new set of wheels in the future
Anyways I appreciate your input, I will do my research again..
mADmAN
1,840
547
the feedback i got saying its a waste of money is bcoz itll perform roughly the same as normal solid rotors. if u want the slots, can just get solid rotors custom slotted
tonyparir
49
508
My rims barely clear the calipers
7jj 40 offset
I think the distance between the rim and the caliper is less than the diameter of the new 20cents coin.
But i need to check again to confirm the distance.
Is that distance safe? Or it is better to get a rim that clears more?
As long as the rim and caliper do not touch. My SUV original rims/caliper is a tight fit even for my small wheel cleaning brush
es2611
951
175
excellent. welcome to the club. whatever. haha.
so how do u feel? worth it all the hardship, hassle and sweat?
mADmAN
1,840
547
my caliper to spoke clearance is even less than urs... barely a credit card can fit... so u should be fine.
tonyparir
49
508
Good to know that lol..
Btw can i pair 262mm rotors with spoon calipers? I read everywhere and was informed everywhere that 282mm is the size to go for
es2611
951
175
i dont think so. smallest rotor size should be 282mm. space needed for caliper to clear the hat of the rotor and caliper could be mounted onto the knuckle.
Thats one huge rotor.. whats the size?
custom. 300mm. with adapters.
tonyparir
49
508
I was told that 262mm can also fit work... Should i just go on with 262mm? or better get 282mm
There are a few things to do to when trying to diagnose a misfire. All vehicles are different, but there are a few places to start.
1)If possible use an OBDII scanner on newer vehicles. The misfire counter function can help you determine which cylinder is behaving badly. Clearly this is not an option for all people and vehicles though.
Note)Even without engine scanners you can identify which cylinder is causing a dead misfire. Carefully disconnect one spark plug at a time. If the...
