Where to do leak test?
g4i8y0t
1,216
330
683
Kedah
Where to do compression & leak test?
My b16a in engine is losing some coolant in small amount. I have replaced the radiator cap and seemed to solved the problem. However, there is some foam under the radiator cap. I plan to do compression and leak down test to confirm that the head gasket is still okay. Any of you guys know where I can do this in the Northern area (Ipoh, Kedah or Penang)?
Maybe northern sifus can help?
Have to be northern sifu dy.
I remember seeing my mechanic do compression test for one of his other client before and just last week he did radiator pressure test for my VR. Found water jacket in between gearbox and engine leaking. Have to take out gear box to replace....:bawling:
Cannot recommend as he is in KL....:smokin:
g4i8y0t
1,216
330
683
Kedah
Update: I thought it's a good idea to do a radiator flush. The foam under the radiator car disappeared after that. Problem solved.
The Marketplace Top Posts
2.2 kit
metal gasket 1.5mm
cam pulley custom
turbine ar70
highcam 272
tial wastegate
os twin plate
injector 1000cc
haltech e6x
full lock lsd
wat do u think about diz mod i mention above? wat the cost? :hmmmm:
