Different between VDO & MMC in wira
wsonny
467
14
5,018
Ampang
Bro,
what is the different in VDO & MMC in wira 4G series? and how can i spot what ECU i'm using now in my wira 1.3 injection
Bro,
vdo use siemens vdo ecu (which the name vdo came from)
-different throttle body special to vdo model only
-use map sensor
-use crank sensor
-distributorless type ignition
mmc use mmc ecu
-similar to other 4g series throttle body type
-use maf sensor
-no crank sensor
-use distributor type ignition (or cam sensor)
Reactions: Ehab abdallah
wsonny
467
14
5,018
Ampang
which mean MMC more better then VDO, and much more space for upgrading as it similar wit 4G series...
RENESIS VIII
7,063
950
Ipoh
Just check these areas that is circled. MMC is different in these areas and also some other less noticeable areas.
Bro. RENESIS showing that you need to have your engine washed.......hhahahhahah
RENESIS VIII
7,063
950
Ipoh
In this picture, it looks ok but I think it still needs more cleaning especially near the block area. A lot of engine oil residue. Difficult to clean that.
sweelt
Nov 6, 2016
2,306
248
MMC got trade in value. kedai potong still want, i think.
my wira 2002 VDO engine, they not even want to smell it. :sleep:
Hi to all of ZTH'ers.
In this thread I gonna show I've replace brake master pump with the repair kit.
I've perform this operation on my wife myvi 1.3 AT with ABS.
The symptom is the brake pedal will go straight away to floor when press the pedal while driving. Everytime has to pump it 2-3 times until can feel the brake operate.
Tools needed
1- C clip plier
2- 12 mm spanner
3- 10 mm spanner
4- 8 mm spnanner
5- tubing
6- bottle
7- 10 mm open end hexagon spanner
1- Contain of...
