Aircond Service
cyful
4
www.friendster.com
My car has clock nearly 300,000km, nearly 8 yrs.... never once i do aircond service. Should i be worry as the aircond still good ?
KenDiriwan
1,283
225
kendiriwan.multiply.com
I suppose you should be able to tell yourself?
But usually by this journey service is required.
If you do a good of keeping your carpets clean, the aircon filter clean, refresh the aircon gases and change the valves, then you should be good to go. No problem don't touch is my belief for aircon.
I thought you new school, service every year......hhahahhah
---------- Post added at 04:22 PM ---------- 6 hour anti-bump limit - Previous post was at 04:20 PM ----------
I am old school and if your air con is still running fine, leave it. With 300k km and 8 years, there may be some corrosion on the cooling fin unit and if you take it out to clean, might just puncture it.
just add some oil to the compressor.
if u are willing to spend more then vacuum the system before putting the new oil.
i learn from bad exp of not adding/replacing the compressor oil.
The Marketplace Top Posts
basically, my question is simple....lets say i get a mivec 1.6 N/A. then i infuse it with a turbo....is it recommendable?meaning of recommendable is that...will there be alot of probs?or just some normal slight problems...if it's recommendable, then what turbo shall i BEST infuse the mivec with?thanks in advance....
