Lightweight Rims 4x108
So now we have established that my stock rims offset is +34mm and i still have 20mm of gap to the fender, so i need to look for rims with +14mm offset in order for the rims to be flushed with the fender?? Correct ah? :confused:
Yup....:driver:
marv3
496
57
Got rims with this type of offset meh? Because most of the rims i see, is all like 30 plus or 40 plus.......Never see such a small figure before....
Got zero and minus even, but probably not with your PCD......:smokin:
marv3
496
57
All the rims i see is like big numbers. 30-40. I never come across 14 or close to this figure :banghead:
Well......At this rate, i think using an adaptor seems to be the option that is shining....Hahahahahah
Use adaptor and change PCD to 114.3 or 100, plenty of rim choices....:driver:
marv3
496
57
If use adaptor you can change your lugs to 4 or 5 lugs, then either 4 or 5 lugs they have rims 8 and 10 holes mah!.....plenty of choices.....lol:rofl:
Can meh??? I thought the adaptor is only meant to change your PCD. But the lugs remain the same?? I was told by a rim shop. Say cannot change from 4 lugs to 5 lugs wor....
Can somebody please verify?:confused::confused:
Can one, see the machine shop skill loh!
Found one picture.....
Most machine shop should be ok. Just whether they willing to do or not only.
Even my suspension the mounting at the bottom was smaller, so mechanic ask machine shop to machine 2 pcs metal cup washer to fill up the gap
After the successful inauguration of the JPM Berjaya Hills Time Challenge in 2009 and other major automotive lifestyle events following it, JPM Motorsport is geared up for the sequel of their hill climb event that is set to once again thrill supercar owners this 30th October 2010.
On board for a second consecutive year is Co-Title Sponsor, CIMB Preferred, who will once again be providing invaluable support to help raise the bar of the now even more prestigiously titled, JPM CIMB Preferred...
