Wira/Satria under car parts
jebatdex
430
18
Skudai, Johor
Dear all
I am planning to replace all suspension/tyre related parts (except for spring & absorber), which have bushing, such as lower arm, lower link etc. The problem is, I dont have the knowledge of complete list of what parts that has bushing to estimate the price. Can someone share his knowledge what I can replace. Front and rear should be different right?
1) Lower link/tulang anjing
2) Lower arm
3) others?
Thanks in advance.
issuzark
861
66
ARB link, control arm, steering rack (not sure if that counts)
IIRC the satay bush is the same for front and rear. But only limited to parts that use the satay bush. Do you intend to keep it silicone or go PU?
Dear all
2) Lower arm
3) others?
Thanks in advance.
Why changing all? They are still working fine, right? Myself, old school, so change only if something wrong.....:driver:
peterj
1,321
258
1,683
Kuching
if really wanna change all undercarriage parts (exclude steering parts)
Front
- 2 set lower arm bushes and ball joint (they do sell bush and ball joint only but mostly now shop sell whole set together with lower arm)
- 2X front stabilizer link
- 2X front anti roll bar bush or a.k.a coffin bush
- 2 set front absorber top mount with rubber
- 2 set front tie rod end,rack end and boots
Rear
- 2 set rear lower arm bush, 1 set consist of 2
- 2 set rear upper control arm with bush
- 2 set rear toe arm with bush
- 2 set rear trailing arm bush (less likely to have problem but should check if wan do one go)
- rear antiroll bar bush a.k.a coffin bush and stabilizer link (mostly only wira 1.5 SE, satria 1.6 and above got ori rear antiroll bar, but do check yours who knows it is there)
- 2 set rear absorber mounting with rubber
all the thing stated above if all replaced... you should have a silent comfort ride already :nurse:
---------- Post added at 11:50 PM ---------- 6 hour anti-bump limit - Previous post was at 11:40 PM ----------
and need check engine mounting also:biggrin:
Aiya, go to Batu Caves area and look for the shop that's the official distributor for Superpro and tell them you want to replace everything and ask for a discount. It'll take about 2 days since some of the bushes need to be machined out.
issuzark
861
66
I'm not entirely sure if OP wants a tank. But that sounds like a good idea. Did you go all Superpro?
That was the very last thing i wanted to do but didn't do yet because I sold the car. I already had some of the bushes and happen to sort of know the distributor boss himself. He gave me a pretty good deal and I was already planning a date. One of the reasons why I delayed the engine mounting replacement.
jebatdex
430
18
Skudai, Johor
So you mean, they just replace all the bushes without changing the parts itself? Can you share the exact shop location/address?
marv3
496
57
Just a quick question.
Will replacing all the OE bush with PU bush such as SuperPro, increase the NVH? Coz i read, some say yes and some say NVH stays same. So maybe those sifu with experience can share their feedback.
synail
259
19
3,018
Some of the bush need to be press fitted...like the trailing arm n the motor mounts if u don't plan to replace the whole unit
issuzark
861
66
Definitely harsher than stock. You also get more feedback though.
Oh damn. If you didn't sell I'd be hearing on how stiff everything feels.
You just kena poisoned, I am sure you have this on your mind now.......hahhahhahaha:biggrin:
I had that on my mind. But it's gone. :driver:
jebatdex
430
18
Skudai, Johor
So I guess this is cheaper (replacing the bushes only rather than the whole unit)? If someone can share the shop address, appreciate it. I think I will go for stock bush.
This is a journey of no return! once our paint is being ruined by such a devastating scratch, the damages is beyond skin deep
physically (on what can be seen) is just some esthetic damage but the real damages is the owner heart broken
Getting to sleep through is difficult, for once i went through it....on my beloved car....especially in Malaysia..people like to take revenge (saying to themselves "i will teach them a lesson -Scratchhhhhhhhhhh their paints)
as I am blogging at the wee...
