urgent help looking for wiring mechanic for blacktop in KL
Merovingian
25
1,503
Hi guys I need urgent assistance to look for a wiring specialist for my blacktop 20v fitted in ee90 se limited. Started off with air con and power window not working. Suddenly while driving car battery died off. Jump start x1 . .. drive a little, n it died again. Wat the hell is going on?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
its a sign your battery or alternator at fault, sometimes the radio also does not work.
start your engine, then remove the +ve battery terminal, if your car still running the alternator is still in good use, battery might need replacement.
if engine dies then alternator needs to be changed.
KenDiriwan
1,283
225
kendiriwan.multiply.com
I just wonder what fuel u guys using after boosting up the engine....let say run at 1Bar of boost,RON 95 or RON 97?
Which brand of fuel do you guys feel it's good?
And if using RON 95 and add in octane booster,will it work like a higher RON fuel?
