Front windscreen polishing
where can i get the glass polish??
Mine I got from Duragloss online. The other Waxco one I think good for removing Rain X only so no point.
If you are free we can try DIY on your windscreen...:driver:
Supra_Fanatics
20,673
3,998
But I use WAXCO Windscreen stain remover :rofl: Actually smells almost the same as the PG Rain-DURA Z
All the Rain repellent smells the same. I know a chemist friend who say it is just a chemical mix. You know the formula can do also. The chemical fills the pores in the glass giving it a smoother finish that is why water beads and falls off. Cannot stick to the glass....:driver:
Supra_Fanatics
20,673
3,998
But if stated Remove Stain from windscreen can it be use on Side Windows as well?
You have the Waxco Auto Clear Vision? Can use to all windows. Not sure how strong or can remove stains because stains can be anything from dropping to water marks.
Supra_Fanatics
20,673
3,998
No no...using this one to clean but I dun think it is strong enough though...maybe need to use a few times weekly...
After using that, I apply this from PermaGlass..
Could be new packing for Waxco....:biggrin:
As mentioned Rain repel stuffs I have so many brands, more or less works the same....:smokin:
Supra_Fanatics
20,673
3,998
Yesterday use was real good but after the car is parked, when rain stop, got some mist on the windscreen. Not sure is cuz of the rain or the repellent. But swipe off with wiper then okay adi :biggrin:
But ya most important it works :smile:
Mist usually happens when difference in temperature. Inside air con colder then mist outside. Like on rainy day you don't use air con got mist on the inside.....:driver:
Hello guys,
I've this problem that my battery is flat due not starting the car for few weeks. Now there's soft alarm sound and i can't unlock my car even manually. Any solution? Is this because the captor system in satria neo?
