Bridgestone RE002 or Toyo T1R Feedback
30,002
They're also about 2 tiers above 002 and T1Rs. :biggrin:
Also C99D, what's the best wet tire for you then?
For me, the GY F1 GS-D3 German made ones.....but discon already
---------- Post added at 03:23 PM ---------- 6 hour anti-bump limit - Previous post was at 03:21 PM ----------
been using both tires but in different sizes, id say RE002 better than T1r in overall stats.
T1r had a slight tendency to "makan tepi" altho i always monitor the tire pressure and chamber. at least for my case.
do u guys really think japan made tires real good? probably good for their weather and road conditions but hell apart from ours.
thats why id say thai/indo made BS/michelin came closest to our weather.
Heard some time ago, Japan uses more synthetics rubber where Asean factory uses more natural rubber. Not sure true or not?:confused:
---------- Post added at 03:27 PM ---------- 6 hour anti-bump limit - Previous post was at 03:23 PM ----------
Theres still all weather tyres and summer tyres ma. Which they have.
Usually the pattern differs as all season have to be able to use in snow, not only rain and sun like us, that is summer tyres.....:driver:
---------- Post added at 03:30 PM ---------- 6 hour anti-bump limit - Previous post was at 03:27 PM ----------
Ah, treadwear. Ok. RE002 isn't that much better either. Mine comes with 220 A A. Heh.
That's quite expensive. Where'd you check? Mine was 205/55/15 for 250 each for 002.
His is 16 inch mah! When sizes goes up so does the price....:biggrin:
---------- Post added at 03:34 PM ---------- 6 hour anti-bump limit - Previous post was at 03:30 PM ----------
Those legal Japan made tyre bring in to Malaysia are made for summer session, so no worry about it.
4 session tyre normally not suitable for Malaysia market, so no tyre maker will import to here, only those parallel import dealer.
Have brother. Hankook v2 concept 2 and Falken ZE-912 are category All seasons....:hmmmm:
---------- Post added at 03:35 PM ---------- 6 hour anti-bump limit - Previous post was at 03:34 PM ----------
I just buy 002 now 003 coming out ah. :bawling:
Can brother, you go more touge loh.......:driver::biggrin:
issuzark
861
66
I mention of T1-R aquaplane resistance not grip. T1-R thread pattern quite a lot of grooves, so aquaplaning kept low, but then less contact surface so grip is not there. T1-R I used before and keep on wheel spin if I power up in the wet. Sidewall also too soft so I need to increase air pressure but then comfort suffers.:banghead:
Whoa wheelspin some more ah. That's quite the scary leh. How many bhp back then? 200?
Also, GY F1 D3 even better rain grip than D5? :pepsi:
30,002
Yup, 200 from engine not wheel....hhahhahhaha:biggrin:
F1 GS-D3 is real good. D5 is actually not the replacement quality, but then did not use D5 before, but from feedback.
issuzark
861
66
So they went another direction altogether. Fair enough.
Hmm, then how much would it be on wheel? :driver:
30,002
In a way, they went toward Asymmetric route, now being their top tyres....:driver:
Never dyno, so do not know the figure....:hmmmm:
---------- Post added at 03:03 PM ---------- 6 hour anti-bump limit - Previous post was at 03:02 PM ----------
How is PS3 compared to RE002? Performance potenza are always overpriced for me
Dry probably RE-002 better, PS3 sidewall soft but in wet should be better.
Supra_Fanatics
20,685
3,998
Noise for me, have never been a problem, exhaust cover the tyre noise......hhahhahahahhaa:biggrin:
For me not a problem. Cuz kelisa noise insulation not as good as BMW. So wind noise covers the tyre noise if there is any. :rofl: :rofl:
Maybe thats the reason why I dont have problem with tyre noise
Supra_Fanatics
20,685
3,998
XM2 also noisy cannot help dy......:confused:
---------- Post added at 02:07 PM ---------- 6 hour anti-bump limit - Previous post was at 02:07 PM ----------
You need earplugs dy............:biggrin:
New is okay...once about 50% thread left then real loud...
Supra_Fanatics
20,685
3,998
Even energy entry level also like that then cannot help already.....:confused:
Need do sound insulation :rofl: But then many also feedback XM2 noisy wor...:listen:
Supra_Fanatics
20,685
3,998
That is why many have ho ha over it until they start to wear and make noise......hhahhahahah:biggrin:
Yala, starting time. All ho ha. Very good and etcs...%#@^ use adi then....:banghead:
Supra_Fanatics
20,685
3,998
Hi,
Are there any way to obtain document/custom paper for a halfcut engine?Let's say i bought a halfcut 4G93 but it doesnt comes with document.How much it cost?
