Evo Malfunction Indicator Light show ?
dkny
211
10
Anyone could give me advice, 2 days ago I try my Evo 8 performance.
From Gear 1 to Gear 2, then gear 2 to gear 3, I pedal like 6~7k RPM, suddenly I saw Malfunction Indicator Light show, I immediate change to gear 4, but lower the RPM, then the light goes off.
I wonder is that normal ? So far I haven't see the light on again, but I quite worry.
As I know, if u driving a VTEC Type R, and if your RPM too high, the indicator light will blind to warm you to switch to next gear level.
So, Evo 8 have this function too ?
pangyau
1,153
302
1,683
Malaysia
dkny,
What do you mean on 'Malfunction Indicator Light'?
Or it is the Engine check light sign?
If the Engine check light while you on WOT (Wide open throttle)
Probably due to knocking while you 'pedal to metal'
On standard Evo, Revving Cut around on 7200RPM.
Or you might hit the Red line too long...
dkny
211
10
Engine Check Light - On
Anyhow DanzEterna, please share me more information, because I really never heard about Evo 7- 9 have "Shift Lamp" function (I assume same function for Vtec K20 car, which shift lamp on if RPM too high).
Probably due to knocking while you 'pedal to metal' - What mean?
If I not mistaken, 8MR redline is 8-9k RPM ?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
if not mistaken evo7-9 has the shift lamp correct me if im wrong....need to double confirm with other evo users
'pedal to the metal' means flooring the accelerator.
usually for turbo cars not that high maybe bout 6.5-7k rpm.
mototo
102
31
5,028
NSW
no shift lamp here. 2003 8 gsr running stock boost, stock rom and caltex 98ron fuel.
regularly sees 6k rpm changes.
however, an aftermarket rom might have the CEL set to trigger as a shift light. Check evoscan and evom forums. I *think* I have read this before but for the life of me cannot remember where or when.
victor87
96
19
1,508
It's knock warning but it's only available on flashed rom...
For AFAIK, Evo 8 with flashed rom to have the knock warning, the CEL will stay on regardless any RPM, and it will only blink if knock is detected. For Evo 9, it's stayed off until knock is detected, then the CEL will start blinking if knock detected.
I see 7,800 RPM almost every time i drive my Evo.....
greenmivec
341
126
Usually for turbo cars not that high maybe bout 6.5-7k rpm.
wrong
greenmivec
341
126
Evo rev cut at 7,800rpm
Beyond that is re flashed ECU or stand alone ECU setting.
Hello to all! Need some advice from you guys out here hehe. Sadly to admit, im dont own a legit evo.. I do however have a 94 Lancer which ive modified its exteriors to mimic the evo3 style.. (hood, o.z rims, bodykit, spoiler). Okay here's my story. As u can see here i'm trying to fully convert my 94 lancer to an evo3.. So far i've completed it's cosmetics but now its time to do the speed. Im sure the easier approach is to get a 4g63T or 4g93T but the problem is I plan to keep the tranny...
