Machine shop / custom made parts / engineering works
Car Shops and Services
infinity.melvin
SlowPoke
1,600
153
kuala lumpur
Hi bro, where is your shop located?
Im interested to do a brake bracket + rotor redrill to pcd100 for bbk conversion. Possibly addition of spacers too.
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
bro avanT, can u fabricate airtrek TD04 turbo actuator downside outlet conversion for FMIC? i'm planning to go FMIC with stock turbo but i dont want to make long pipe from top. i wanna turn the turbo outlet downside like TD05..
AvanT
Custom fabricator & CNC machining
360
113
Yes Bro, did it with other mech, but shody job, anyway it has been endorsed already. .but can feel slight vibration, can you quote me the price for those mountings..thinking of changing it to a proper one, mine is 3 units of mounting (4x4).
Thanks in advance Bro..
Hi Kim, I will need to take look at your current setup & mounting to determine a costing. Rest assured it will look & perform as OEM ones.
What 4x4 u having? My younger bro just completed his project... A Kia Sportage, running a S13 SR20DET, LC2 front & rear axles, and PTO winch.
kim78
Jun 10, 2013
10
Wah lau wei!! So radical mod job you have up there. Mine is straight forward conversion, Sorento with 1jz-vvti, hat's off to your Bro's mech. Can you pm me the rough figure for those mountings. Thanks Bro.
AvanT
360
113
Hi Melvin, thank U much for your inquiry.
Yes, we're able to do all the above U mentioned.
We're located in Kepong, Taman Ehsan.
However, I can only take up your job after June due to relocation & setting up new machinery.
I sincerely hope U can wait & let us assist U with this project of yours coz I'm looking forward to work on a Ford Fiesta project.
Avant, I have drawings in CAD format and want a quote on how much to make. Possible? Just a quote, no need actual item to be done.
AvanT
360
113
Mr wilson,do u got transfer gear cover for locked gearbox?
Hi there, is this for your Waja + RVR turbo + evo gearbox ?
---------- Post added at 01:38 AM ---------- 6 hour anti-bump limit - Previous post was at 01:36 AM ----------
Yes bro, email me the drawing at [email protected]
Apologize for the late reply, was away for a while & have relocated my shop.
Qty U need for the part to quote?
---------- Post added at 01:41 AM ---------- 6 hour anti-bump limit - Previous post was at 01:38 AM ----------
Where your shop location..? I want to custom bracket my honda civic
Hi Cerry, I'm located in Sungai Buloh.
U may contact me @ 012-283-3635.
aisay, I already had the part made last 2 months. Nevermind, next time I'll come find you for other parts I wanna do
Ryuuken
204
98
Subang Jaya
Bro,do you do custom intake manifold and 4 Throttle for 3SGTE? And also,could you do an intake pipe with for 2 Open Pod Air Filter?
AvanT
360
113
Hi Ryuuken,
We have done custom intake for Mitsubishi 4Gs, 6-throttle for Skyline GTR, but have not on a 3SGTE. Question...can U provide the intake manifold gasket & individual throttle bodies? I can help U with the fabrication, but will need U to gather all necessary parts for us to start with.
modesto007
131
hi bro,
will be you able to do this as per photo in 02 and 04 ?
i need that hollow cylinder with thread then top mount screw and bottom threaded screw for it. this is for front and rear.
spring i can get it elsewhere.
thanks bro,
AvanT
360
113
Hi bro,
Thank U for your inquiry & apology for the late reply.
Sorry to inform U that we are unable take up your job because we operates CNC milling machine, don't have a lathe machine for this kind of job.. =(
hi bro,
thanks bro,
Hello... i'm got 1 big problem with my WIRAEVO3. My car only at car park for about 2 years coz i'm not around. After 2 years come back then kenot start. All of Power Distribution tested to my friend SATRIAEVO3, same engine. ECU, Distributor, Power Transistor, Spark Plug+cable+Coil. Starter funtion normally, but no spark from plug cable.
If got any sugestion to dis prob. pm me. Thank U bery mac.
