Try roll your fender...
how if load with full passenger ? the rim will hit fender or not ? :questionmark::questionmark:
wah.. this style is low budget style? KW must be nuts to use "budget style" on their competition range. hehe.
i wonder how a separate springs style looks like?
Nope... did not hit the fender at all with all five passenger in the car... Im driving a 2008 Myvi...
That also depends on your rims offset. If using original rims and tyres sure will never scrub the fender....
I am using 15 inch rim with Michelin PS3 195/50/15 tyre...
yup... really depends on your offset rim as well...
HWL and Zerone adjustable with one is batter?
Dear All Guru, I'm driving a Grand Livina. I have drove my car for 3 years and it is just right after my manufacturer warranty. 1 thing i don't like about this car is the original handling, it floats and alot of rolling during moderate cornering. Therefore i have initiated a modification plan for my car to improve the handling. After some research, 1st i have installed an anti roll bar together with the strutbar, it improve a little bit and i'm quite glad about it. Then i proceed on the next stage where i have done an installation on the suspension to install an adjustable. What i have done here is, i have chosen zerone ssr300 however the wheel is still in stock mode (15inch but i'm planning to put a 17inch in the future). After the installation, the height in between the fender and the wheel is about 3 finger away, i had test drove my car in a couple of highways and i felt my car is stiffer however it is more adaptable to the ground and more handling furthermore the cornering is good with less body rolling. But what i don't like is the feeling of jumpy whenever i drive thru most of the uneven road in a moderate speed. To add on, i'm still diving my family along certain time and they claim that it is jumpy and not comfortable at all. To be frank, sometime when i'm driving alone on certain uneven road i do feel jumpy and it causes me to feel my car less adaptable. Can you pls advise me on whether i have done a wrong setting and how can i fine tune it again to make it less jumpy while driving uneven road? Thank you so much.
HWL
The problem here is you went for zerone ssr300. That's a Hi/Lo. Meaning you're at the mercy of dampers and spring weight. What you need is a hi/lo/soft/hard. At least with that you can adjust soft or hard settings and make sure you get the one with the bodyshift feature so you don't compress the springs when adjusting height.
I wouldn't modify a family car. Why? Cuz family will be your biggest critics!
So far I get praises from family instead wor No complains and etcs. Just need to mod according to their needs or something we think they need then is fine most of the time.
Unlike our own car, we mod to our own liking. So putting an adjustables in a family car with stiffer settings is gonna just end up wasting money by setting back to a softer set up since is a family car. Wife & parents going to complain.
You got mod adjustable suspension meh?
Don't have, did plan to once before but end up with Sports Suspension only. Well, lucky didnt. Parents complain it was stiffer than before. After that they got use to it since is acceptable stiff rate.
That is what I mean. If fit adjustable I am sure they will complain......hahahahahaha
But so far, I tried in Titanrev's saga. HWL adjustables seems fine to me. But maybe like he said front driver and passengers still okay. Only passengers at the rear will suffer
You sit, your butt ok, but parent usually different.....
Tell them..."U will get use to it"
Training them in my kancil. They drive before. They said is like a bone cracker
Similar threads | |
Q | |
Similar threads | |
