Perdana V6 Community Forum *
kurt_629
872
54
johor
hello Danz,
wanna ask.
for V6, we only need to change the timing belt?
is there anything else that need to change?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
hello Danz,
wanna ask.
while u at it I suggest to change water pump, spark plugs & plug cable, at least u save on workmanship. to change water pump alone will costs u the same for changing timing belt, same goes for the plugs & cables.
---------- Post added at 11:56 AM ---------- 6 hour anti-bump limit - Previous post was at 11:55 AM ----------
Hi Danz,
Thanks for your input, that means MYR690 is a good price mark. Wah 8 hours?! didnt expect to be that long...btw u mind sharing any workshop that has expertise in pv6?
duration will be from 6-8 hrs depending how busy is your mechanic.
my previous workshop did a very good job on my engine, but sadly I made him bankrupt & closed shop because he took my car for a ride & had an accident.
I advice find a workshop close to your home at least its convenient.
kurt_629
872
54
johor
noted on water pump.
spark plug, i'm on iridium.
is there a need to change plug cable? i thought if it aren't spoil, don't bother.
what about fan belt? is there a need?
V6, run how many belt in total?
my savvy runs on 3 belt, engine, aircon, radiator if i got it correctly
YYC
1,833
939
Hi you guys have any idea how much it costs to do top overhaul and full overhaul?
A brand new v6 engine I heard was rm4,000.
DanzEterna
15,911
3,371
it depends on the brand of the top/full overhaul set,
top set from japan bout rm160++
full set from japan rm250++
during the process u might replace wear & tear parts therefore budget less than rm700 for top overhaul & less than rm2k for full overhaul
that is an estimate price.
workmanship depending on mechanic
YYC
1,833
939
Thanks for that info. The estimation doesn't include timing belt, spark plugs etc?
kurt_629
872
54
johor
anyone?
---------- Post added at 09:29 AM ---------- 6 hour anti-bump limit - Previous post was at 09:27 AM ----------
sorry, i never done overhaul before..
so wanna learnt..
why overhaul got top or full set?
i thought overhaul refers to a process whereby it cleans almost everything in the engine..
which is better?
top or full?
The V6 is a pain in the a** even just to change the plugs. So many things to remove, so is better you change whatever you need to. As for plug cables not too sure, better bro. Danz comment on this.
Some car have different belts to run air con, alternator and so on and some just one belt runs all. If have not change before might as well change now since opening up
---------- Post added at 09:58 AM ---------- 6 hour anti-bump limit - Previous post was at 09:54 AM ----------
hello Danz,
wanna ask.
Other then those mentioned by bro. Danz, I think you need to change the internal oil seals too. Tensioner and bearings if have?
---------- Post added at 10:01 AM ---------- 6 hour anti-bump limit - Previous post was at 09:58 AM ----------
anyone?
so wanna learnt..
which is better?
top or full?
Usually if your pistons and rings are still in good condition they will do a top overhaul. Remove only the header de-carbonize, grind the valves, clean up and put back.
If need to change pistons and/or rings then is full overhaul
DanzEterna
15,911
3,371
anyone?
so wanna learnt..
which is better?
top or full?
pv6 got 2-3 belts, cant remember, aircond, alternator & power steering.
yes overhaul there are 2 types, those emitting white smoke from exhaust can just change the oil seals & gasket known as top overhaul, meaning only open the engine head.
full overhaul will dismantle your whole engine leaving the engine block inside, some mechanics will take it out too. I did a full rebuild on my engine the last time it was worth it at least engine can lasts another 10 years.
if u ask me of course full overhaul will be better if u have the funds, if not top overhaul will just do fine.
---------- Post added at 10:20 AM ---------- 6 hour anti-bump limit - Previous post was at 10:18 AM ----------
yes unker u are correct, it could costs up to rm360 for workmanship alone to change those plugs, so must as well change at one go, plugs & cables.
timing belt set will include 1x timing belt, 5 oil seals & 2 tensioner bearings.
vemalv6
Mar 31, 2014
6
Hi all .. need help ..my v6 has been jerking so n chk gb panas so install cooler .. still gt jerking .. tukar fuel pump nw no jerking .. bt wen driving .. will be fine a while n thn suddenly tekan minyak like to power at all n engin shutdown .. plz help
We have here a grey BMW F30 today, for some light corrections and Optimum Coating. Initial conditions of the car was that it is in quite a good shape, paint was clean, seldom driven as the owner was waiting for us to do the coating before he drove it. The only defect we could spot was...
So as we can see from...
