Subaru Legacy BP5/BL5
Dayline668
1,810
492
1,683
Sorry, wht is MI?? So if i get BP5, i have to use RON97?
MI = Motor Image Malaysia
JDM is on Ron100 in japan, minimal Ron97 also can cause engine check light on full boost assuming never tune. But can be detune to run Ron95 no problem.
nyne
264
67
selangor
ooo i seee, since all of you guys Subaru expert. i would like to ask, how much would it cost just for a standard services? wht is the budget like?? is it the same to maintain as the conti car?. I really love BP5 though.:biggrin:
Dayline668
1,810
492
1,683
Apple to apple, 4wd to 4wd, its nothing diff. I would say cheaper then conti depend on the part u choose, i put it in better perspective say timing belt kit with waterpump ori subaru vs gates with japan made water pump is rm2k+ diff between them. Normal maintenance is +-rm300 every 5k km, GB oil + F/R diff +-rm500 every 25K km, should keep them in tip top shape, normal wear n tear is unavoidable so its depend on the car n how well the pre-owner maintain it, after all its 10year old for the 1st model bp5, if u bought a lemon u can't say the orange is no good.
There some common problem with power steering pump on all newage subaru till ver10 grb, need to chg oil regularly to keep it problem free. Other then that its down to how well the pre-owner maintain it.
nyne
264
67
selangor
Great info broo, thanks and much appreciated. Currently im using Volvo S60 2005, soo pretty much maintenance is almost the same, but the diff BP5 is 4wd. If i change to BP5, does not make any different since both age is almost the same.
DeaconFrost
284
159
Was told the same thing by AE.
Went to AE for checkup, car confirmed accident free, engine & gearbox problem free. But steering feels a bit heavy during idle & parking. No leak spotted but was told by AE this is common problem up to Impreza version 10. New pump will cost RM2k++, chop shop RM1.8k.
Quick check on the overseas forums shows solution ranging from flushing, tightening belt to tightening bolt. No pump replacement mentioned.
Anyways, anyone care to share how many mm tyre-to-fender clearance for a spec.B JDM?
---------- Post added at 10:38 AM ---------- 6 hour anti-bump limit - Previous post was at 10:33 AM ----------
Filled up with Shell FuelSave 95 when odomoter shows still 70km worth of fuel in tank (no fuel warning light yet).
Full tank is 51.45 litre.
Dayline668
1,810
492
1,683
P/S pump can be serviced, chg oil seal etc... Keeping the fluid fresh is the key here.
Stock spec-b 18'' is 18x7 ET53, u can go for ET45 without rubbing fender.
Advice to not use shell ron95, alot of member had problem with fuel quality, endding with engine limp mode etc... I personally ban shell. But its up to u.
Happy boosting...
DeaconFrost
284
159
Changed wheels to 17x9 ET30 last Saturday, poked. Surprisingly rubbed at the back but not at the front.
Changed wheels to 17x7.5 ET42 on Sunday and doesn't rub at all. Happy.
First report of full tank:
Fill up: with 70km worth of fuel left
Refill: with 70km worth of fuel left
Fuel brand: Shell FuelSave 95
SI Drive mode: Sport
Distance travelled: 435.6km
Fuel quantity: 51.45 litre
L/100km: 11.81 (50% urban, 50% highway)
Manufacturer claim: 13.1 (urban), 9.4 (highway)
Just filled up with Caltex Premium 95 with Techron at 7pm.
Dayline668
1,810
492
1,683
Full tank get u 4xxkm is normal, but the fuel trip meter not accurate just a estimation.
I always fill up when the light came on.
DeaconFrost
284
159
Totally overlooked the fact that Subaru's wheel offset and width fitment is very different than other cars.
In a RWD Toyota, I can put wheels below +15.
In a Civic, I can put 7.5 width +32 offset and it sits flush with the fender.
In an Airtrek, I can get away with 8.5 width +28 offset. Poked at the front but never rubbed.
But in a Subaru, the OEM wheel is +55. Wut? Always thought +4x is too much hiding.
Dayline668
1,810
492
1,683
Imprezza sti can use up to +2x 9jj
aku_sangap
1,172
15
Tengah Laut
MI= Motor Image....official Subaru Dealer here in Msia & Singapore....:D...
RON97 for optimum performance. If wanna use ron95, u need to reflash / remap ur ecu (power will drop)....:D....
cooper1275
1,070
hi guys,
still trying to get Legacy wagon, where do i get parts in KL/Selangor?
Scooby reliable workshop recommend pls,,,, tq.v.m.
Unveiled at the shores of Lake Como in northern Italy, the stylishly Italianized Z4 roadster had its sheets pulled off to reveal the BMW Zagato...
