Basic Performance upgrade
4gbanger
1,958
386
1,683
Johor/ShahAlam
well im not so sure but the its only minor jerk and felt like abit power loss. it also happen when i'm at low rev cruise..
zaifulaika
Dec 24, 2013
32
5
508
bro, i have just about the same problem like yours.... starting from few days back, my atr start to 'cough' when cruising lower rev (below 3000). loss power and also jerking when cruising at steady speed. this morning, started to jerking even bad. Ask around before, some said because of the air flow sensor, some said because of the O2 sensor and the other told me because of the crank shaft...
anyone can give me a hand here.... :confused:
biao
348
24
perak / ipoh
if is air flow sensor problem, u pedal heavy let the turbo kick in, when the jerking come, the engine will look like have a emergency brake, total pull back the power and when u have pedal but no any response. so i think is air flow sensor is time to change. cos i just change 1 only before cny, because i wash it then spoil already.
4gbanger
1,958
386
1,683
Johor/ShahAlam
well based on my experience, O2 sensor is the last resort. if air flow sensor kong, ur FC and power loss and also it affects the idling problem, ur car even barely drivable. better check the plug, plug cable or ignition coil. last time my car jerking really bad when revving above 4000rpm full throttle. found out that i use a wrong sets of plug. it was denso iridium IW20(meant for stock everything). i was suppost to use IW22 or IW24(meant for boost above stock)
Hello Zth forumer!!
Do anyone know where place/shop that can recond back Racing Clutch Plate.
Please list down here with place/shop name & phone number.
Thanx :regular_smile:
