Polish caliper
dreamZz
326
Hi all sifu,
I tried to polish d aristo caliper using grinder, anyhow its hard to polish d narrow space...any1 know what chemical can i apply to easily erase d origin black color.
I wish to have shining silver color effect after d polishing n apply d clear coat to it so it can long last for d shining :)
mADmAN
1,840
547
tried paint remover?
fazidk
413
5,183
Paint remover/acid is more then capable of doing d job:)
dreamZz
326
u can try wire brush to polish the narrow space. use fine wire brush.
Tks for ur idea bro...will hunt for it at hardware tomolo... :D
---------- Post added at 09:30 PM ---------- 6 hour anti-bump limit - Previous post was at 09:28 PM ----------
What do you mean sand blasting withstand heat. Sand blasting uses sand to remove the paint only...
Oo....miss understanding...lolx...
ken yeang
6,617
1,327
use a dremal tool. it can be used with various polish, grind, cutting heads.....
There is a liquid I saw at my mechanic's place where he uses to clean the car engine cylinder head. He just submerge for a while then clean with water and like new, but I think is costly and not worth your while. For them it is for business and the liquid can be used many times..
dreamZz
326
I used it too...but d narrow space really hard to sand..lolx
---------- Post added at 10:14 AM ---------- 6 hour anti-bump limit - Previous post was at 10:13 AM ----------
Ic...tks for d info.
i remembered I did saw a pic that shows a kancil with the 1300cc K3-VET engine. I would like to ask is that really possible? No problem with the JPJ?
So one K3-VET + installation worksmanship is how much? I also need BOV, intercooler, turbo timer, piggyback ecu remap and all this dashboard meter thingie.....
So if we can install the engine, what about the gearbox? can install also? I wondered if it has CVT..... Also I would like to ask if we can strengthen the gearbox and install...
