Review: Firestorm Ignition Coil Booster
Interesting review and discussions. I was offered this by a shop in Sunway too & was told that for Mark X, I need to use minimum 1 Super FS, maybe even 2. But I still worry if it might have some negative effect. The difference in spark looks quite scary in the video. :biggrin:
Should the plug gap also be increased when using FS?
Give one demo unit to Izso and if it gets his stamp of approval, im getting one!
thanks for your vote of confidence. But this test would be an extremely long one. I'd want to make sure it doesn't fry my coil. Any boosters would indirectly affect the power source.
quicksilver7
313
66
This product on the Inspira increased torque (less than 5) until 3k RPM. Then both lines intersected and began moving away from each other.
[This was based on a Millenium's dyno by a group of Inspira owners wanting to prove the effectiveness of this product on a dynamometer]
cvkit17
2,884
1,354
Intersected and moving away? Which is on top and which is below?
Hmm that doesn't sound good then. But maybe have to be tested on a few more cars before drawing any conclusion.
cvkit17
2,884
1,354
That's probably how it helps more in auto cars...bringing up the lower torque. It is certainly good if we can have dyno charts to view..
goohtj
57
12
5,008
l had it installed in my Saga Blm 2008 last year.
in city drive, this Firestorm does perform. car is more lively n engine noise is lowered.
but in higher speed during highway, the car seems like being shunt n lost of power.
in conclusion, it is good for car with low rpm or drive <120km/h.
tried on my nazaria, no feel.
Inside an auto Waja 1.6, what do you call the panel showing the gear changes - P, R, N, D, ......? Can this plastic part be changed as the cover has been broken/defaced? Does the gear knob and the whole PNRD... have to be changed together?
Will appreciate if you can give me the name for this gear control item. Hope the picture I have can be seen.
