Not sure about those two, but after installing Stiff Rings, cars don't feel faster but then more stable and comfortable onlyLet me ask you guys with UR bars or chassis strengthened via spot welding :
1. Does your car feel faster than normal with the stiffer chassis? Even though you're only going at 90km/h it feels like 120km/h?
2. Do you have creaking problems and how do you solve it? Especially those with bars.
3. Does anyone have ill-fitting plastic bits after installing the bars or after chassis stiffened?
Ya I watch Top Gear Korea too, but too bad they don't have english subtitles cuz I can't make out what they mean in Bahasa.one thing for sure comparison with my caged car and non caged car....
during bumps/uneven surface/hole/jump the chasis remain stable...no awkward wild handling sign....especially if this happens during mid corner....
*and it appears that stiff car chasis seems like it was moving slower (while speedo show otherwise) because of the increased stability....
#yesterday i'm watching top gear korear on KIX channel.....the artist got time attack using golf gti car.....i saw really how stiff golf's chassis during that time attack because in corner the inner rear tyre easily lift-off from the ground...(pushed by other side tyre via anti-rollbar)
I have the Racetech CAK. I found my handling to be very twitchy and steering input super sensitive. I don't like that on normal roads but on track that's quite useful.Not sure about those two, but after installing Stiff Rings, cars don't feel faster but then more stable and comfortable only
Handling improved.
Weird.. you're the opposite of me then. So far I've managed to scare all my front passangers with my driving and never once did I exceed 110km/h. I notice all of them having a very quiet serious face and all of them grab hold on to the handhold at the top.one thing for sure comparison with my caged car and non caged car....
You might be seeing things slower like Takumi Fujiwara than your passengers, biggest possibilities is that your passengers never drove their car fast? :hmmmm:I have the Racetech CAK. I found my handling to be very twitchy and steering input super sensitive. I don't like that on normal roads but on track that's quite useful.
When I ask them they all say the same thing : "Why you going so fast?"
Then I tell them to look at my speedo.. 80km/h or 90km/h at most ever.
I'm at a loss. My slow-turtle of a car is scaring people when I drive slow. My only suspicion is the stiffer chassis and feedback from the car, it's affecting the passangers somehow? Or does anyone have any theories?
I'm about 90% UR-bar-ed up. Only bars I don't have is the undercarriage 4-pt bar and rear undercarriage 4-pt.
After installing the stiff rings, they just told me to tighten those bolts undercarriage once awhile...even if u didnt fix stiff rings or anything, no harm getting the mech to tighten or check on the bolts.strengthen chassis after few years so there's no any loose screw?
Aisay man.. that's exactly what my alignment/camber is set to. And removing the bars is a pain in the a$$ la. All of the bars are very difficult to remove except the front tower strut and room bar. Everything else requires a lot of removal and I'm kinda lazy man. LOLok then its time to try n error remove some bars and test again....
as per CAK...perhaps u can adjust the alignment toe to 0.0 (dead center) and camber -ve1.0 all on four corner.......that amount of camber still decent for daily road use and help stabilize the car on the straight
I've had mine checked a few times already. Each time checked with a impact gun, each time it's already super tight. Never loosened at all.strengthen chassis after few years so there's no any loose screw?
Yes, small and simple but impressive results. Obvious Results.got my ride installed with the stiff rings ... so far just tested one day.. i am kinda impressed.
but cant really know which is which as i installed 2 things together .. :P ..
but i did test a satria neo with a stiff ring .. quite noticeable improvement i would say
Anyway, it isn't really a problem for me. It basically discourages people from getting in my car. When passangers ask me what the room bar is for, my usual reply is :
"To make my passangers uncomfortable"
