i think that symptom is like the car is not getting fuel.something weird happen while i was driving. lights so dim and everything seems to be dim. engine loss power aircond also no power. car feels sluggish. then everything went back to normal. i've check the battery and charging alternator but no problem. wiring problem?
try check fuel pump see if its working nicely or going to die soon?
my FC in putrajaya (town-ish area) is around 7.5-8.5km/L depending on how i drive (speed demon or drive like a grandpa)thx NeuroOne,
btw...my full fuel tank ~RM105 is getting me as far as KM450 only is it normal or something is wrong? meaning average 8.2KM/L my Celica turbo is getting the same with lots of boost :hmmmm:
my FC for hiway is around 10.5-11.6km/L also depending on the speed either follow the hiway speed limit or be limited by the speed cut. hehe..
ATF cooler get Hayden 677, or Works Engineering.Hi guys, i just bought my 2001 PV6 in a week! So far am happy with my car. I've already service the engine, change engine oil, oil filter and change the atf fluid. I'm yet to install ATF cooler for my gb. Any recommendation from you guys? JASMA,HAYDEN WORKS?
And maybe you guys could assist me on what to do next.
I heard it is standard for a V6 to have wind noise when speeding more than 100kmh. How to void the wind noise? need to replace the rubber trim or......? no idea how to solve.
Other than that, I love my new V6 even tho bought 2nd hehhehehe
i will avoid Jasma cooler.
my car does not have any weird wind noise except for when the plastic on the chrome lining of the front windscreen terkoyak.
and now, i think the weather strip (rubber lining on the doors) are wearing out after 10 years..
not touch up gasket, u replace terus the gasket, put in new gasket and seal it nicely.Danz : Mech says better don't touch up to gasket, cause after changing engine might loose pressure/power. Says it will never be the same as ori... so i'm prety worried to do a top overhaul.
Still in dilemma ... Kasi angkat engine first lah then decide what to do.
there's actually a transparent plastic covering the chrome lining.HI bro Danz, you have mentioned the windscreen's chrome strip. What to do about it if it creates wind noise?
that's what usually cause the weird noise..
just potong the plastic..
