(DIY) Homemade Plate Flipper
idnawse
205
36
perak
Caution: -Bad English- sorry
the idea came when changing new bumper .. noticed that be4 tis using promote bumper my engine will cooling quicker compare current bumper (special edition). Maybe the design itself (promote holes bigger than SE bumper) cause this problem. Plus, adding reg. plate no. will block more cold air goin' through the radiator (really?)
So... I need the flipper for the plate.
items needed:
2 x motor (fm digital aircond blower box)
metal bracket
power window switch
DIY tools
Motor (use 2 for left and right)
Using 1 side motor only, the other side need to remove motor inside the casing). Solder 2 wires direct to motor coz i dun hv the socket.
made a additional holder fm thick aluminium, than rivet to the holder @ motor casing. Both side.
Perfect (so far)
try put @bumper
Cutting and clearance checking process using cardbod
Seal around using gasket gum (what a waste). Supposed use silicon gum but lazy enuff go to hardware shop.
Put back @bumper and connect 2 motor holder with metal bracket. Than put the reg plate.
Using this diagram on power window switch to control flip up and down
Done. Dunno how to put video here..but can view here d3c3pt1c0n: DIY Homemade Flipper
Result: Ok la so far..Next project will be indicator for fully flipped up or fully flipped down.
har1th7
371
42
hahaha....smart.... good for AES also
cvkit17
2,884
1,354
Nice DIY...but I got 1 question. Can the motor withstand the weather e.g. rain and water splash? Coz the casing doesnt look like water proof and has electronic circuit running inside
idnawse
205
36
perak
oredi sealed around the casing with silicon glue (pic 11). didn't use the circuit board coz i solder the wires direct to motor.
I have a thought. Say you're travelling 120km/h along the highway and you activate the switch. Will the motor be strong enough to handle the wind resistance and all that?
idnawse
205
36
perak
test oredi @160-170kmh speed all the way (gopeng-ipoh PLUS) .. both position (up and down) no problem.
red line - the area still covered by the plate, so no possibility to crack/broken (normal position)
2 layer metal bracket - enough oredi to hold the plate (flip position)
alantjw
1,566
128
nice one.... :biggrin:
ronaldindin
207
29
www.12bet.com
walao this is really great idea! But I've heard this kind of adjustable plate holder is illegal right? But they're not that free to check one by one anyway
idnawse
205
36
perak
illegal - if been caught :biggrin:
btw, i flip down at highway onli...and still slow down when reach AES area ..hehe
Jul 25, 2013
Hi, saya nk tanya.. u still blh modified plate flip ni ker? please need to modified..
blh u send email no contact u at my email...
[email protected].
items needed:
metal bracket
power window switch
DIY tools
Perfect (so far)
try put @bumper
Upon Collecting his new car, my buddy , has been searching a lot on lne toward A-Z coating avail in the country
some of the dirt seen upon arriving our Hive
door jam
dirt found...
