Car Idling & Die Off All of a Sudden During Heavy Traffic...
DanzEterna
15,910
3,371
www.primeperdanaclub.com
because for my car, if battery or alternator gonna kong, will give all sorts of symtoms like power window
not working, radio on off itself, headlights dimmed.....so at least i know its giving signs 1st before completely kong.
30,002
Erm, not sure how to do it, guess will send to workshop :rofl:
P/S: I wonder why I always bump into you and you didnt say hi. I even got ZTH stickers.
Should have help me la knowing im also zth member :rofl:
Instead u just switch lane and drive off in your bentley...:banghead:
Hmm...best i leave it to the mech to settle...
Probably bro. Danz in another car might have stopped. In Bentley, after people think Bentley breakdown instead.....:biggrin:
arturo
nooB
2,722
1,083
SateCelupLand
auto restarted engine woo...thats the wierdest part. it requires a very specific circuit to be engaged to crank the engine to start...n funny thing is the circuit knows how to auto off crank when the engine started...if not sure can hear the starter screaming when engine already started.
u have immobilizer n remote start alarm?
Supra_Fanatics
20,685
3,998
My situation reminds me of the scene where Takumi AE86 Die off :rofl: all the lights just go off like
that....
Nope, just normal OEM immobilizer and alarm. Yes, that's the weirdest part. That is why I did
mentioned that when I open the bonnet, I was surprised to see everything is running,
car is back to life...:confused: :dontknow:
Hard to believe, but believe it. It did happen like that...:listen:
30,002
that....
Hope your car don't turn out to be "Christine"
Car Horror Movie..... Christine (1983) - [email]IMDb@@AMEPARAM@@http://ia.media-imdb.com/images/M/MV5BNDA0NDkzNzc3Nl5BMl5BanBnXkFtZTYwODk5OTI5._V1._SX78_SY140_.jpg[/email]@@AMEPARAM@@BNDA0NDkzNzc3Nl5BMl5BanBnXkFtZTYwODk5OTI5@@AMEPARAM@@SX78@@AMEPARAM@@SY140
---------- Post added at 02:22 PM ---------- 6 hour anti-bump limit - Previous post was at 02:20 PM ----------
go buy 4D with your number plate...:) its a sign....
if strike lottery gimme 20% enuf k....faster go buy now....:listen:
Fuyoh! 20% cut......:biggrin:
Supra_Fanatics
20,685
3,998
If strike, will use to convert it to Corolla XRS 1st then nicely do it up, got balance I belanja THE SHIP :rofl:
(20% cut of the balance I have left) :biggrin:
Will watch later, cuz now start work liao haha
Supra_Fanatics
20,685
3,998
got kena 4D yet anot? :listen:
i wanna order my 4G63T halfcut for my car hehe...
Balance only enough for engine kosong only wor..:rofl:
If he buy 2 big, 2 small, then after he use, balance you get 20%, maybe enough for Mee rebus with teh tarik only.......kakakakakaka:biggrin:
Haha! Still can get Mee Rebus and teh tarik means can consider I'm very generous already...:laugh:
15,390
SupraFan : I had this problem before on my Wira. At first I thought it was my ECU and then my battery and then the alternator.. finally I gave up and thought it was a ghost.
Then a friend pointed out my battery terminal connector wasn't clamped on tightly enough (battery lead too small) so I swapped to a proper sized terminal and problem solved.
Don't use spacers or whatever to make the battery hold, swap out the terminal to make it fit on the battery lead.
Supra_Fanatics
20,685
3,998
This reminds me of what my dad told me after I check with him on what was done to the
car since I did not drive it for months. Battery was replaced by a workshop at Jusco Kepong.
But he said he was told that the battery connector is smaller than usual, so he guess the
connection to the battery is not that good.
Thanks for sharing bro Izso, at least got a clearer solution to my worries now.
But the problem I faced during the process, was my left headlamp was not working.
Just 2 days ago when I drove that car at night, realised both of my headlamps
are no longer working now.
Any idea what causes it? Since battery connection is not that right, couldnt be causing
the headlamps not to work anymore right? I was driving with fog lamp only on that night.
Will get it check and let u guys know what's the problem. Didn't have the time to send
the car for repair yet but I can see some corrosion on battery.
Supra_Fanatics
20,685
3,998
Lights not working, check fuse, bulbs, if not, then switch and wiring.....
Ever since that incident, lights not working now. It was okay when the car was back
alive. Now lights are dead.
Fuse I just give it some knocks cuz not sure which fuse is the one. Gonna get it check.
Previously was because of my switch in the car that was having the problem.
Switch already replaced with new one then solved the problem.
Should have sold off the car last time but so far the car is a great to drive car...
15,390
When I had the same issues as you, the damn thing shorted my headlight relays. Does your Toyota use aftermarket headlight relays? Check the relays. Idle your car and have someone switch on and off the headlights. If the relays are working you should be able to hear 'clicking' noises. If not then the relays are spoilt, just replace.
If you aren't using headlight wiring kit, then it's very likely your fuse. I'm not familiar with the layout of your car but there usually are only 2 places to check for fuses, under the driver dash and in the engine bay. Anything else in your car dead together with your headlamps?
Supra_Fanatics
20,685
3,998
if its a proton sell it off...but a toyota....could be minor problems only, try Izso's method...might solve your prob.
Yea, 200,000+ km mileage and have yet to overhaul. Still running good so far. Touchwood. 1ZZ-FE
is indeed a strong and good engine.
Yes, when it happened, that damn thing really did shorted my left headlamp, then after that, now both are dead. Will try that when I'm back, I didnt turn on and off but didnt pay attention the the clicks. But when my car revived again, both headlamp is working. Now dead again.
My Corolla is using headlamps are stock, so relays should be OEM?. Never change before. Nothing else is dead except the headlamps. The mini bulbs running light in the headlamp is working,
just the bigger bulb is not working.
So, kinda dangerous to drive. Guess I have to use BLM up to Goh Tong's empire tomorrow. :frown:
Using fog lamp alone not bright enough.
30,002
Toyota leh......:biggrin:
---------- Post added at 02:05 PM ---------- 6 hour anti-bump limit - Previous post was at 02:00 PM ----------
Another concert?
Supra_Fanatics
20,685
3,998
Another concert?
No la, people meeting, I meeting, I have to drive 60KM+ uphill just for 1 hour meeting...
hang around for awhile shaking ding dongs and go back...
30,002
Wah! go hill top for meeting. Nowadays, stuck in office as now handling over my duties....
As you know black cars are a lot more prone to visible dirts and water stains, is there any special of specific brand of car polish/car wax that we can use to further enhance the shine and to repel dirts for black?
Its for my sis car and i'm actually recommending her to use Featherlite which i am using but her car is so prone to watermarks. Maybe there's something i can recommend. Anyone?
