EG clubs/owner etc
arturo
nooB
2,721
1,083
SateCelupLand
peterj....no longgar? piston slap on cold start must be horrible...
this question if for shiro if he comes back...
i got real bad knocking on my b16a (stock standard with some minor pnp). i've tried retarding the timing till the level when exiting a junction becomes really dangerous (press accelerator and can only hear *broaaaaap* but really sluggish pickup) but the knocking is still there. i've tried using ron97 and its reduced but still there. what can be done? where should i check? i've had dizzy failures in the past so i'm running a halfcut dizzy, ultra plug cables and standard honda plugs. can a standard ecu be tuned to reduce the knocking?
mADmAN
1,840
547
stock shouldnt be having that kinda issue... could be other possible hardware failure...
but if u wanna tlak about ECU... then i guess crome would be the cheapest n most bang for buck solution... can tune ur a/f ratio as well as ur ignition timing.
ChyanHonda
Jul 6, 2011
20
madman, how much the crome ecu in the market now?
mADmAN
1,840
547
avantech doing it for RM550 inclusive of dyno rental for 1 hour... if take longer then have to top up.
zhaf_b16
487
is it really best bang for buck solution? RM550 including tuning ke bro?
where's bro shiro? have he tried the dc2r front arb into EG? PNP or not? hehe.
mADmAN
1,840
547
yeah....crome is the best bang for buck management for us right now... said to be the same level as Hondata S100
include dyno tuning bro... dyno kat USJ. kalau ECU takde tapak utk chip... add RM100 for the tapak.
crome = nice....
madman...if hardware...where to focus on? dizzy?
typically when knocking...yeah dizzy....but try other plug cables as well...
suggest bringing to a workshop to fully diagnose though...especially to check the distributor
If doesn't include tuning, dyno 1 hour rental for what?? :rofl:
BETUUUUUUUUUUUUUUULLLLL!!!!! HAHAHAHAHAHAHAHAHAHAHAHAHA
EDIT: this arrived today from weksos after waiting for 2 weeks :D
Prothane Shifter Bushings
arturo
nooB
2,721
1,083
SateCelupLand
madman....dizzy hard to find good unit. halfcut units all going for at least rm750/unit
recond unit cant even touch. use half year already dead.
rm550 is without tuning rite? sasuke is charging ard RM800 for everything include tuning n dyno...
mADmAN
1,840
547
wah lan neh... already posted how many times INCLUDING DYNO TUNING.....
as for dizzy...sometimes it can be fixed.. thats what my mech did for me..works like a charm... if ur near shah alam head to sri muda... Fast Autoworks and look for Ah Keong (the boss)...
he takes bits n pieces from other dizzy to repair n fix...
arturo
nooB
2,721
1,083
SateCelupLand
madman...mine oso now bits n pieces from various other dizzy. n i'm keeping a spare coil n igniter just in case. the dizzy when gone really just gone. cant even start the engine up.
550 with tuning is really not bad price...they will give 1 map or can ask for 2 seperate maps? cos i have the software here n if can have 2 seperate maps...can store in notebook n switch when syiok hehehehe 1 map for FC....1 map for heavy foot wakakkaka
mADmAN
1,840
547
the mapping part i dunno... coz crome is basically a custom chip... and once the chip is burned with a map...dunno can re-burn it again or not..
n crome is not like hondata where u plug in USB and simply play with it... u actually have to use an emulator (which is an entirely different hardware) to setup the mapping etc.
if u wanna play switch-switch... then ur gonna need to have 2 chips...n change out the chips when u feel like it.
arturo
nooB
2,721
1,083
SateCelupLand
madman....u really power la. yr idea is totally ingenius. i can get the engineers here to make a hot switch n mount both chips with a toggle switch on the dash to switch between the 2 chips. no need motech anymore! hahaha
but seriously...i saw some guys in the states saying they play with the mapping themselves cos the crome software can download free from the website n u can play with all the functions.
mADmAN
1,840
547
i had the same idea too....but cant figure out a way to switch 24 pin connections at once... hahahha
yeah u can download the software free... but thats just the normal crome... not crome pro which needs to pay...pro got data logging somemore n some others cant remember....dunno how they play with it la... but to setup crome ull need a chip burner and an emulator.
Hi guys.......need ur help a bit on where to find a 5 Speed gear box to be converted from a 4 Speed gear box? How much is da cost?
