Burned rubber smell
wwilliamm
Jul 12, 2012
47
6
508
Has anyone experience it before? As I'm experiencing it myself currently on my myvi 1.5 auto tranny.
After a couple of hard rev's with my windows slightly down, I could smell the burn rubber smell
coming in. Stop the car aside, pop the hood and found nothing was wrong as the smell is coming
from the engine bay tho. Any suggestions? :confused: :hmmmm:
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
There might be a possibility its your tyres that are new giving that smell...
But pls dont take my word for it...
Just drive and when the smell comes stop at the nearest petrol kiosk and put your nose near the wheel to smell if its the same...:smokin:
wwilliamm
47
6
508
Sure. Bring it to the workshop for inspection
Nyantong, yeap would definitely ask the sc on my next OCI.
Lesly, thanks for the info will check it out if the smell arises again. Only happen during hard rev tho.
punk
360
76
Negeri Sembilan
Might be burned engine oil smell..
I drive few car also have smell when drive it hard.
I think not a problem but check ur engine oil, or anything that is visible around the engine bay that is burned
wwilliamm
47
6
508
Hmm, how do i know if the engine oil is burned? I tried checking around all the cables and fuses but everything seems to be fine.
wwilliamm
47
6
508
u won't notice because only little amount of oil burned.
I think suppose to be relate to oil catch can.
Okay here's the thing, I just double check and my engine oil is at the proper level, timing belt not slipping and the auto transmission fluid is still pinkish and no burn smell. Weirddd! guess I'm just gonna ask the sc.
punk
360
76
Negeri Sembilan
u got my meaning wrong:banghead:, i mean small amount of engine oil circulate through ur throttle body and intake manifold when u drive it hard.
The more i write , the more confuse u are.:listen:
wwilliamm
47
6
508
Check ur brakes
Yeap, that I'll pass on to the sc to check it.
Lol I was just double checking on the engine bay only. And I get what you meant :)
spoon civic
403
36
terengganu
maybe your pad brake burning?some engine oil can cause burning smell when u high revving..i think there's no problem la....many new cars when high revving can cause that smell bro....
Supra_Fanatics
20,673
3,998
I only smell burnt smell from other cars when coming down from genting but thanks for sharing, at least something new to take
note.
spoon civic
403
36
terengganu
if there no burned equipment,maybe your engine oil burned when high revving..its ok then..just check wheter the loil decrease or not.if decrease from the safety dip level..shlud add some....your pad btake burned also can give smell...............
wwilliamm
47
6
508
it was your catalytic converter smell.. it was normal for stock car nowadays.
I see thanks for the advice :)
Could be your ATF or engine oil dripping on the exhaust, thus giving the smell..
Check if theres any leaks....
Did double check my engine bay, no leaks on the ground as well as on the heatshield of my stock extractor so yeah.
doubt is brake pad because i brake hard and no smell only after high rev's from 4k-6k.
after a couple of weeks the smell will be gone...
Hopefully it will haha.
note.
Agree to that !
Did double check my dipstick tho, level still the same never decrease. And can't be my brake pad as it only happen during hard revs. When I hard brake there isn't any smell only got the " Squee Squee " sound lol.
peeche
395
165
Sin City, MY
every time i chase a car with this smell.. i knew they are still using the catalytic converter.. most of them with stock exhaust.. the smell only comes when u revved the car hard.. that is normal for nowadays car bro.. the catalytic converter burned excessive build up that goes through them..
tyre burnt la hard rev=spinn tyre sure got burnt rubber smell :driver:
my bro lost his car on yesterday morning in front of the house... a perodua kembara ct aero 1.3, black colour, BHS 1527, in Oversea Union Garden (O.U.G).
Please contact me at 012 2320290 if anybody got the information.
Thanks!
Rewards will be given if the car found.
