rbp super single clutch
mADmAN
1,840
547
Need review for rbp clutch...
Nak beli tapi takot cepat masak nanti
sometimes u have to be the guinea pig.... unfortunately...coz its either u...or someone else....tapi nak harap someone else mmg susah la.....
my advise, go for it... but keep ur stock clutch just in case....if u dun like it then u can switch back n try to sell that clutch....either that or get used to it....but at least u have a backup.
yes its expensive in terms of labour etc to be switching around...but at least ull find out for urself...
n of course itll be good for the car modding community if u share ur findings as well.
another option: DnD oso has super single clutches that has the same applications as the RBP...but dunno good or not...their twin plate clutch is currently in Avantech's EK9 Turbo track car...havent heard feedback abt it yet though
i have no idea when or how this started but i'l give you a quick run-down.
the spark plug area of the 4g93p rocker cover is seeping oil. most probably from the 2nd, 3rd and 4th spark plug bolts. no crack is visible. oil starts to appear in that contained area after driving and shutting off the engine (it seems that way).
so far, here's what i've done to try and rectify the problem:
1. thought bolt threads have worn out, so changed all 4 spark plug bolts. also, these bolts were...
