Mahle, CP piston
bvalve
2,330
16
群&#39340
MAHLE & CP piston, anyone heard of it or using it? Comment?
Or beside this 2 brand, any other brand with the price range almost same with the 2 piston brand i mentioned above.
mADmAN
1,840
547
good stuff... go for it...
mADmAN
1,840
547
google "piston to wall slap"
but mahle and CP uses an alu grade that doesnt need as much piston to wall clearance as some brands like wiseco and ross racing which uses a diff grade of alu which requires a lil more piston to wall clearance.
theres pros and cons on each alu grade in regards to pistons... ive posted some info about it on this forum before..feel free to search my posts... cant remember where it is
so the lesser piston to wall clearance, the lesser the chances of slapping. note: "lesser" chances... not "zero" chances.
cmng
3,289
72
dont mention piston slap la
look like use piston to slap people only
need warm up before you whack the car
or
when start the car from cold. the car is vibrating kaw kaw
need to warm up and wait the piston expand only smooth
AlucarD
1,079
115
5,163
Tell us what is the application for. Drag, Time Attack, Endurance, Street, high boost, high compression? The piston should be suitable to the application. Power levels? Don't buy based on name only. Talk to your tuner. He/she will be able to advise you based on your requirement.
Forging material will depend on your application. 2618 is heavier and expand more so you will need to have more piston to wall clearence. 4032 is lighter and will expand less so you will need less clearence. Also depend on how you intend to run in the motor. Gentle run in or all out high boost at the dyno. Do your research on google and talk to your tuner. Both forgings also have different wear characteristics and it's pro and cons.
Piston slap is not a bad thing. It all depends on your piston and it's intended usage.
those was F1 piston manufacturer BTW :biggrin:
reintel
732
30
3,028
Both brand is good. What you should be worrying about is the size, material, design etc.
But DON'T look for piston made from 'JASMA'. Definitely not a good idea
D7zul
2,697
848
Shah Alam
Hehehe.. JASMA is not a brand name
its only a copycat item sold here in M'sia
Everything jasma is not good except for exhaust system brought in from japan
[PIMPIN]
2,138
648
Actually what's the price like for both Mahle and CP anyway? A bit hard to suggest when have no idea of the price range.
The Marketplace Top Posts
Hey,guys. many times,we want to buy wheel spacers for our cars, but what should you consider before buying it? Today, I will share 3 importent things must be considered before you buy wheel spacers. Because safety is the most importent thing for you.
1. Safety is our first consideration when we buy wheel spacers. The high quality wheel spacers usually use forged 6061-T6 / 7075-T6 aluminum alloy materials. Grade 12.9 extended wheel bolts&grade T10 wheel lug nuts. It can improve the handing...
