3S-FE,GE,GTE Discussion/Gathering
kkyen
276
3,018
selayang
hi guys, I'm just got my sw20 rev 2, notice that my car having fuel cut issue even with stock boost, how can I fix it? thx
zeus83
979
55
KL-Damansara
kkyen,
at boost its cutting off?
Sentul63 & xMika,
Celica 4WD GBs are not designed to be locked to 2WD...that one is for TOWING purposes only
just sharing my experience...
ST171 GB which is Code S54 and i had it in my ST202 3SFE. have good shifting/acceleration but cant tahan lama if you abuse it
im using E153 from old Lexus ES300/Camry Solara, it has taller gears but not as fast as the S54 when it comes to fast shifting
my 2 cents
peterj
1,321
258
1,683
Kuching
Hi all zth bro,I post behalf of my fren,we are looking for 3sgte turbo header for st205,newer gen that use map sensor,we tried old gen with maf sensor but the header won't fit...and the header I looking for is single outlet since my fren converting to single outlet turbo,do notify me where can find,thank you all..
xMika
623
85
Selangor
kkyen,
ST171 gearbox is code S51 .. S54 not yet on the market that time until the celica/mr2 period ..
zeus83
979
55
KL-Damansara
Thanks for the info! S51 was made for camry and solara not corona though...just checked Toyodiy (not sure how accurate)....corona used S50, S52 or S53
S54 is very similar to the corona Transmission
I believe SW20 MR2 3SFE 1990 was using S54..correct me if im wrong :biggrin:
---------- Post added at 04:39 AM ---------- 6 hour anti-bump limit - Previous post was at 04:37 AM ----------
whats you engine block? have you tried mudah? i rmbr seeing ST205 header for sale sometime ago
xMika
623
85
Selangor
I also checked toyodiy, if says S50, 52 or 53 for corona gearbox then it is haha ...
Turbo MR2 uses E56 ... non-turbo uses S54 .. i think so
GT4WD
630
Hm... has not been updating the page for long time...
How guys doing? lolz
What’s the deal?
Naza-Brabus, the exclusive sole distributor of Brabus-tuned cars and Brabus performance parts in Malaysia has taken the opportunity to preview its Startech Refinement program with the local debut of The Range Rover Evoque Startech. The exclusive event is part of the many activities held during the Naza Merdeka Auto Fair...
