mods on Accord CF4
Ceffy_999
225
Hi guys,
My friend is facing problems on his CL1 euro R gerabox. The problem is he facing crunch sound & hard to change to 5th gear from 4th gear when high rev. Below 3k rpm no problem.
Is it syncho problem? Or change gearbox oil can be settle?
Is it normal problem for Euro R gearbox?
jdm_jdm
121
16
Hi guys,
Transmission grind d..... Someone miss shift badly before .
aja
4,696
35
5,148
Hi guys,
● Crunch sound while high revving gear change
● Hard to engage gear during redline
It's mainly due to the retainer spring on your clutch plate...
BTW, If u are using stock clutch, don't rembat2 that much - if not this will happened so soon.
Go and change to new clutch..this time by racing type if u are a racingboy! kekekekekeke
alwhitesat
760
30
So busy logging in so many forums.....
ANyway.....any of ur frens suffer problems again with VW ?
My bro....his 1.4TSI.....if rev to max....all lights at the dash lights up !~ Terrible....hahaa
abe fobs.. size??
sato san, vw seems to have a lot of problems.. my friends gbox just kong..
contis.......trust only merc, just merc
Hi guys,
had this problem when i first bought my car......solution to this, just pour mineral based engine oil to the gearbox, use only 20w-50 grade, and always service at 5000km interval
Ceffy_999
225
Engine oil into gearbox? then no more sound at all & no more problem on your gearbox?
So should I change the clutch 1st? Will this happen if the clutch going to finish soon?
I am using stock clutch...Why stock clutch can't change gear on high rev so frequent?
alwhitesat
760
30
problem solved immediately after using the oil, no sound, no crunching, u will shift smoothly afterwards...i've been using the oil almost 4 years now, also in sepang track, no issues at all!!
and it's nothing to do with ur clutch, unless the clutch pump also got problem, better check for leakage
Even merc also kong gearbox.....especially the latest models
Having issues with the ABS also......
A merc mechanic told me....
meh??? we never face any problem with our mercs.....
fairy
644
Hi guys,
ceffy_999.. i faced the same problem on my sir-t and also on my cl1.. 1st adjust the clutch pedal higher..then try.. if cannot try mtf3 honda gbox oil.. solved my problem.. still cannot it means taking the gbox apart.
awitgg
186
Hi & Salam All, long time since last check in the thread. Just to infom that im selling my subaru impreza wrx sti 03/08.. Pls check out the market place for more info. Tq2...
Ceffy_999
225
Yesterday just change the gearbox oil & check the clutch pump already (no problem). Still facing the same problem. Plan to remove the gearbox next month to check & change the clutch & clutch cover as well.
1. Just wondering if it's syncro problem, how much would it be to buy a brand new syncro replacement? The syncro is only for 4th to 5th gear?
2. Can the syncro be repair? As some foreman said it might can be repair.
wan_iswandy
530
2
alwhitesat said:
problem solved immediately after using the oil, no sound, no crunching, u will shift smoothly afterwards...i've been using the oil almost 4 years now, also in sepang track, no issues at all!!.
I used to have same prob with my sir-t.. Replaced gearbox oil with 20w 50 engine oil, same as alwi.. 2 years already, no more gear synchro issue..
Ceffy_999
225
Then I will try the 20W 50 engine oil. By the way, any engine oil which is rated at 20W 50 will do?
And also how frequent need to change the engine oil on gearbox? 5000km or 10000km?
fairy
644
what oil did you use?? i asked about the the syncro was around 600 plus..
The Marketplace Top Posts
We will be show casing this 3 months old Nissan Teana. Although it is not a special car but you would be shocked to find out that this is actually a 3 months old but yet looked like a year old car. Owned by a very well known fashion designer in Malaysia, she called us to save her ride from rotting to the ground.
From a distance the car looks like is in a good state but lacking some waxing. We...
