Campro head skimming
jackisblack
388
5
kuala lumpur
adf.ly
campro engine head cannot be skimmed...the idle will 'lari'...if u already done it,u MUST use good quality metal gasket that thicker than the original gasket..cannot use carbon gasket again..
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Agreed... that the advice the Proton SC gave to my sis when her persona engine overheat.. they quote rm3k for the whole head assembly + rm260 labor charge
punk
360
76
Negeri Sembilan
how to know the correct thickness of gasket after we skim it...
Let say i gonna diy top overhaul, in market only two type which is carbon(ori) and metal gasket rite..
The thickness of the gasket got many measurement sold?
nyantong
192
50
The idling probably has to be readjusted with Proton's factory diagnostic. Its available at Proton Service centres.
misai
6
3K...whoaaa....3k = dismantling plus change new head?
---------- Post added at 03:32 PM ---------- 6 hour anti-bump limit - Previous post was at 03:15 PM ----------
is there any effect by doing this?
let say head and block already skim...
how about engine temp?
should i remove the sensor?
punk
360
76
Negeri Sembilan
should be no problem la bro,
as they mention using thicker good quality metal gasket after skim...
crazykatak
776
48
Subang Jaya
The cylinder head can be skimmed. Just to flatten the surface.
remember only to use genuine cylinder head gasket.
no such thing as "quality" metal cylinder head gasket..OEM ones are already metal lol
thickness of the cylinder head gasket ( when seen closely are made up of two layers of super thin metal ) is about 1.00mm ( if im not mistaken ).
then, properly torque the cylinder head during assembly..most kebabom / "head jahanam" are caused by wrong torque value, wrong torque sequence..then comes wrong torque value of camshaft caps.
**Genuine campro head gaskets are made in Germany :)
punk
360
76
Negeri Sembilan
U mean after skim just buy a new set of original top set??
If we already skim to the limit maximum, we just use back ori set gasket ??
The piston won't hit the valve??
Just asking only, thinking to diy long time ago but nobody can get me the answer..
sorry ya misai,,kacau ur thread..
crazykatak
776
48
Subang Jaya
if you skimmed 1.5mm, add 0.5mm ( assuming OEM head gasket is 1.0mm ) thickness of cylinder head gasket to maintain correct compression & also to prevent unwanted valve langgar cases.
misai
6
no problem la punk....we here to share....
---------- Post added at 08:09 AM ---------- 6 hour anti-bump limit - Previous post was at 08:02 AM ----------
there some1 tell me not to use metal gasket after skim...he prefer use 2 layer carbon gasket to get correct thickness...any comment?
is 5kg per piece without tyre consider light weight for 15" rims? planing to change to light weight rims.......
hope sifu here can help me out :)
