neo
xw4600
68
508
what is the difference between vq25dd and vq25de
1) which one have neo.
2) how much price difference
3) how to sitinguish ( any photo )
4) power ratio and fc
chteo
176
15
Subang
Wikipedia will answer 1, 3, 4.
2 depends on chop shop, and whether engine kosong or whole half cut, but expect 1.8 to 2.5k for engine kosong (with trade-in of your old engine) and 4 to 6k for half-cut
chteo
176
15
Subang
Yup, but so far never heard of anyone putting in a neo into a32, not sure the engine mounting fits or needs modifications or not
sb3
1,141
14
5,138
I heard that the old VQs (DE i think) gives higher toque specs and hp.
chteo
176
15
Subang
from Wikipedia:
VQ25DE
This engine is similar to the VQ20DE, but has a 2.5 L (2495 cc) displacement. Bore and stroke are 85 mm and 73.3 mm, with a compression ratio of 9.8 to 10.3:1. It produces 190 PS (140 kW; 190 hp) to 210 PS (150 kW; 210 hp) @6400 rpm and 174 to 195 lb·ft (236 to 264 N·m) of torque. Later versions produce 186 PS (137 kW; 183 hp) @6000 rpm and 171 lb·ft (232 N·m) @3200 rpm. (1994–1998 Nissan Cefiro A32)
VQ25DD
The 2495cc engine has Bore and stroke of 85 mm and 73.3 mm respectively, with a compression ratio of 11 to 11.3:1. It produces 210 PS (150 kW; 210 hp) to 215 PS (158 kW; 212 hp) @6400 rpm and 195 to 199 lb·ft (264 to 270 N·m) @4400 rpm.
It is fitted to the following vehicles:
1999–2002 Nissan Cefiro A33, 210 PS (150 kW; 210 hp) (JDM)
sb3
1,141
14
5,138
VQDE & VQDD produces the same torque and horses ?? Then, why bother to change to the DD versions?
chteo
176
15
Subang
again from Nissan VQ engine - Wikipedia, the free encyclopedia:
The VQ is a V6 piston engine produced by Nissan with displacements varying from 2.0 L to 4.0 L. It is an aluminum block DOHC 4-valve design with aluminum heads. It is fitted with Nissan's EGI/ECCS sequential multi-point fuel injection (MPFI) system. Later versions feature various implementations of variable valve timing and replace MPFI with direct fuel injection (marketed as NEO-Di). The VQ series engine was honored by Ward's 10 Best Engines list almost every year from the list's inception. The VQ series replaced the VG series of engines.
Hmm...I knw tis is about car crimes and security post but my story is not relate 2 car crimes n security 1...jst wanna share a story which experienced by myself...
hmm...i was studied at penang n which my hometown at sungai petani which at kedah state...it happend at the sunday night which i m going 2 penang...i was b with my fren with my fren drive another car...here is the story..whn i was at the highway,the traffic gt abit jam...so only can 100km/h at the 2nd lane...whn i see rear view...
