neo
xw4600
68
508
what is the difference between vq25dd and vq25de
1) which one have neo.
2) how much price difference
3) how to sitinguish ( any photo )
4) power ratio and fc
chteo
176
15
Subang
Wikipedia will answer 1, 3, 4.
2 depends on chop shop, and whether engine kosong or whole half cut, but expect 1.8 to 2.5k for engine kosong (with trade-in of your old engine) and 4 to 6k for half-cut
chteo
176
15
Subang
Yup, but so far never heard of anyone putting in a neo into a32, not sure the engine mounting fits or needs modifications or not
sb3
1,141
14
5,138
I heard that the old VQs (DE i think) gives higher toque specs and hp.
chteo
176
15
Subang
from Wikipedia:
VQ25DE
This engine is similar to the VQ20DE, but has a 2.5 L (2495 cc) displacement. Bore and stroke are 85 mm and 73.3 mm, with a compression ratio of 9.8 to 10.3:1. It produces 190 PS (140 kW; 190 hp) to 210 PS (150 kW; 210 hp) @6400 rpm and 174 to 195 lb·ft (236 to 264 N·m) of torque. Later versions produce 186 PS (137 kW; 183 hp) @6000 rpm and 171 lb·ft (232 N·m) @3200 rpm. (1994–1998 Nissan Cefiro A32)
VQ25DD
The 2495cc engine has Bore and stroke of 85 mm and 73.3 mm respectively, with a compression ratio of 11 to 11.3:1. It produces 210 PS (150 kW; 210 hp) to 215 PS (158 kW; 212 hp) @6400 rpm and 195 to 199 lb·ft (264 to 270 N·m) @4400 rpm.
It is fitted to the following vehicles:
1999–2002 Nissan Cefiro A33, 210 PS (150 kW; 210 hp) (JDM)
sb3
1,141
14
5,138
VQDE & VQDD produces the same torque and horses ?? Then, why bother to change to the DD versions?
chteo
176
15
Subang
again from Nissan VQ engine - Wikipedia, the free encyclopedia:
The VQ is a V6 piston engine produced by Nissan with displacements varying from 2.0 L to 4.0 L. It is an aluminum block DOHC 4-valve design with aluminum heads. It is fitted with Nissan's EGI/ECCS sequential multi-point fuel injection (MPFI) system. Later versions feature various implementations of variable valve timing and replace MPFI with direct fuel injection (marketed as NEO-Di). The VQ series engine was honored by Ward's 10 Best Engines list almost every year from the list's inception. The VQ series replaced the VG series of engines.
I have a set of GAB HA for AE101 that needs fixing. I have sent it to one of my friend's shop but they say first generation cannot be fixed. I have heard that all GAB can be fixed whether first or 2nd or 3rd gen. Anyone can shed some light on this?
Many thanks!
