My neo 1.6AT FC Problem
xtremeleo
3,247
464
5,183
its much bigger then the original size imo, so u need to add sum percentage on the tripmeter reading
XlimShady
283
19
Had the same problem with my new CPS when I just got it. FC was 12/100km to 14/100km for city driving. Found out later it was due to my extremely heavy right foot.... had to learn how to drive sensible.... That time got new car too exicted. But now after 1 year + FC is great I would say. Average on my meter now 8.4L/100km. (city driving + long trips from perak to KL about twice a month)
Jerry_ann
26
6
1,503
With this tyre and rim size, you can add around 2.5% for your actual mileage.
But i have no idea your rims are made in which country.
monsh
157
18
i'd say 15 is better for neo .
the lowered look and the lighter rim gives u a lot more power and better look as well :)
and change ur extractor to 4-2-1 .
and please be reminded when u buy a 2nd hand car, always go for standard maintenance at least .
best if u could spare some for top overhaul or even better, full overhaul :)
do like others said, check spark plug, air filter, clean throttle body, change 4-2-1, change to 15"
and i believe u could restore ur system.
Don't forget to reset ur ECU .
fishyogurt
From Facebook
23
www.facebook.com
thx for all the info and other guys too...will do it one by one....lots of $$ @_@
---------- Post added at 07:28 PM ---------- 6 hour anti-bump limit - Previous post was at 07:24 PM ----------
but if i change my rims back to 15 inch...can i change to a wider one?
reefdee
97
5
1,508
Putrajaya
my 2 cents.. if you are willing to sacrifice abit of comfort, then go for 205/45/16..
then get those lightweight rims..for 16" make sure each rims are no more then 5.9kg per rim.. that should offset abit the disadvantages of using 16" over 15"..
monsh
157
18
for 15" mostly is 195/50 or 195/55 .
hardly find 205 nowadays i think .
if go for 16" rim, get those original which is lightweight and better build compared to cap ayam.
and also, i think 45 is a bit too thin for daily use.
road in msia really crap, a lot of pothole, u dont want to end up with a bent rim :)
Dayline668
1,810
492
1,683
Even if u rev it all the time also will not drink petrol like this, same like my 2.2 subaru lol... Better send to specialist do full checking. Proton will not fix this kind of problem for u. Check o2 sensor etc is more sensible.
My GTi's coin box door can't be closed due to some problems with its' latch. Somehow, the old latch wasn't latching to it.
So finally I had some time on my hands and decided to become a MacGuyver for today and dip into my dad's tool box. I found some magnets, screws, metal washers...and viola.. the idea of a magnetic latch like on those cupboard doors came to mind.
Anyway.. below are some photos of my DIY for those who are interested. If they don't appear here, then you may go to my...
