Need help on rpm meter
l2s_turbo
1,068
154
Hi bros, i need some help/advice from you all.. i've already converted my v6 to rvr auto turbo.. problem is my original v6 rpm meter seems like vy "heavy"... which the mechanic told me because it was actually for v6 engine not for 4piston engine thus it become like this. So i want to ask that if i were to change/modify the rpm meter isit possible without changing the whole meter? Because i like the current meter with the 240km/h reading.. those japanese meter only up to 180km/h.. can modify ka? Please help please help.. :adore::adore:
l2s_turbo
1,068
154
So many views but no one replies.. sad... :bawling:
i dunnow if pv6 meter housing same with rvr meter or not....maybe u can just swap the rpm meter part and use back old meter???
*just a wild guess :adore:
l2s_turbo
1,068
154
Cannot bro, i have the rvr white meter, but it looks boxy.. unless custom fit.. but the meter also max till 180km/h only..but i saw online ppl selling pv6 meter but he wrote there if perdana S4 need to use back the old rpm motor.. so dunno can be done or not.. he just write there only..
NeuroOne
WFH
2,074
181
Putrajaya
i use a Eterna 4G93 meter cluster as it is for a 4 piston engine.
but the meter is only up to 180kmh la.
i dont mind as long as the speedo and rpm is correct.
i mean the meter cluster itself separated by rpm,speedo and other gauge 3separate part in one meter casing (if i'm correct on wira meter..not sure about perdana)
or like neuroOne's meter maybe can take out the rpm cluster only and install on stock pv6 meter cluster....this one have u have to double check if can fit or not.... :adore: just my suggestion to DIY....can't confirm work or not....
l2s_turbo
1,068
154
l2s_turbo
1,068
154
its somewhere at the gearbox....u will see a connector.
But has anyone here encounter the same problem which after changing the meter to japanese de solved? i'll get the speed sensor checked too..
NeuroOne
WFH
2,074
181
Putrajaya
its not the speed sensor. its the rpm one.
speed sensor will connect to the speedo and odo.
i dono if u can disconnect the internal parts of the meter to replace the '6piston rpm stuff' with '4piston rpm stuff' but mostly pomen will fit a 4 piston meter to ur car.
but like shah decapullet, he uses the latest perdana V6 meter (with the chrome rings) for his Evo3 engine..
mines998
1,048
149
If really cannot then get after market speed meter lor. Even my RS meter using on TT engine also having some variance after 100km/h. I using Defi VSD and GPS vs my RS meter found out Defi and GPS are same reading but RS meter slightly lower.
NeuroOne
WFH
2,074
181
Putrajaya
speedo on car almost always slower by around 3% than true speed.
i checked/tested on various cars with GPS speed..
l2s_turbo
1,068
154
Hmm in that case must ask bro shah decapullet.. how he mod his v6 meter for his Evo 3.. paging for bro shah decapullet..
My friend's waja missing
details:
Make: Proton
Model: Waja 1.6 SOCH (A)
Colour: Silver
No Enjin: 4G18P-HF9017
No. Chasis: PL1CF1SRR1F004405
Reg No: TAA 6262
Description: Bumper belakang ada 2 sticker "Spitfire" kat reverse sensor. Bumper depan belah kiri & bumper belakang belah kanan ada kesan calar.
call owner - faizal
012-3242814.
