Your 195/50/R15 is new? Running FWD, the front will wear first and if cannot rotate since you are using different size (aspect ratio), you will have to keep changing the front tyres until the rear ones wear down....Thanks vr2turbo for the clarification! Much appreciated!
Why you did not use back same size, means the 55 series? Is it too big?Correct! My front tyres are almost bald. The rear ones are still very good. Been using about 2 - 3 years.
By the way, is the yoko parada any good?
But normally higher series will have problem in the rears, especially when rims offset too far out.there is a scraping sound when i turn.. Don't know if it is because of the 55...
In that case you better check properly first, if you have not bought the 50 series tyres, because 50 series tyres usually are made wider then 55 series tyres......That's why i am considering 50's. Just wanted to be sure before i change from 55 to 50.
I want to know if there will be any difference.
Thanks for all your replies buddy, i really appreciate it =)
Not the current price as not so popular for this model.Ahh.. ok, noted!
Would you happen to know the current price per piece?
