Blow Off Valve.....
Elmo_X
309
2
just want to ask any pro and cons of replica greddy RZ / RS bov ???
i hear from zerone shop saying max boost 1 bar after that " BOMB " the bov and get a new 1 so he recommend me get a orig RZ greddy
whats your advise otais
jinkl
4,624
376
3,183
haih, some ppl still dnt understand wht surge is , hmm
its nt the bov tht makes tht sound
achelone
125
27
you will hear the surge sound when the bov set too tight and during throttle release. the throttle body shut immediately and the pressurize air is trapped and travel back and forth throttle body and turbo compressor. the psshh psshh psshh sound is the pressurized air moving in between. really cool but not recommended if the boost is high.
bov sound usually will discharge once not psshh psshh psshhh. AFAIK FYI :D
---------- Post added at 12:54 PM ---------- 6 hour anti-bump limit - Previous post was at 12:53 PM ----------
MKMD428
876
190
5,043
johore
the air will end up at air filter. thats where the sound produced. thats why i said listen carefully between BOV and airfilter.
MKMD428
876
190
5,043
johore
i experienced it when using Sard R2D2. piston bov kaput. spring lost its elastic ability.
Elmo_X
309
2
just want ask turbosmart kompact series bov are they made out of plastic??? and can it be weld on stainless steel intercooler piping??
mengz
605
4
3,018
what are the symptoms of the BOV not holding?
i'm not sure if my BOV is leaking. lately my boost cannot go past 1.1bar. but it's holding steady at 1.1bar.
is this a sign of the BOV not holding and leaking boost? im using a Greddy Type RS. car was tuned to boost at 1.4bar.
Heres the answer to all your minor dents, bumps, bruises and scratches... say good-bye to them as Dr. Dent The Automotive Perfectionist is here to restore your rides away from dents and bruises.
Call Williard Yong at 012 238 1010 for a free consultation
