Blow Off Valve.....
mines998
1,048
149
663
If BOV can't hold pressure be it spring rate too low or the Teflon inside already worn off this is quite common beside that you boost on 1.4bar high boost.
R11
Jun 20, 2011
33
9
508
AFAIK, the selection of BOV/DV/BPV is related to the ecu tuning either by using MAP or MAF sensor as an air/fuel mixture load source.
If your can is running by MAF sensor based setup and you plan to use the BOV VAT (vent to atmosphere), the afr will run rich as the calculation of air is based on the mass airflow metered.
the loss air vented to atmosphere is basically metered/calculated air needed by the ecu for this combustion mixture. besides the car running rich, you might have a problem to get a stable idle.
some OEM ecu can be remap / reflash with using the MAP setup, but in addition you have to have the 2/3 bar map sensor if the factory setup doesnt have one.
Happy boosting guys..:driver:
mengz
605
4
Thanks for the info bro. So the reason y my boost can go past 1.1bar could be due to leaking bov right?
mines998
1,048
149
663
Is better you let workshop to check for you to confirm the problem. Boost can't hold can be from...
1. Piping leak
2. Wastegate leak
3. BOV leak
4. Boost controller leak.
avaultz
478
guys..
currently im using hks sqv. since its leaking i plan to change to greddy type-s..
so my question is, can i use back my current adapter or must use greddy adapter instead?
thx
mines998
1,048
149
663
Immitation also can use just dont know how long can last but even original some time also must depend your luck.
MKMD428
876
190
5,043
johore
thx for the info bro..
btw any1 been using hks sqv imitations? how's the quality? it seems non adjustable, wont causes turbo surge?
doesn't last long.. if u happened to stumble one using it w/o problem, it's luck.
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
I was using ori japan ssqv 1 before, but no sound,
after using ssqv2 taiwan it works now....
mine is from taiwan...as long as yr boost below 1bar u should be fine...
if more than 1 bar use greddy
enkei_rs
40
Now using Blitz ss series on my 6A13TT with 0.6 Bar maximum.
But sound not so loud and normal "kepish" sound.
Any advise with nice sound and work with 0.6 Bar.
Admire the bird chipping sound.
avaultz
478
mine also ori sqv 1st version.. but its leaking now.. whistling sound when u boosting. (4g93t 0.7 bar)
been using it for 4 years ++.. bored with the sound so plan to change to greddy type-s.love the type-s sounds but i read lots of negative reviews about piston type bov. soft spring,diaphram tears,jams and etc.
any methods or tips to diff ori sqv with imitations.. worry get con.
mines998
1,048
149
663
It you don't mind the sound maybe you can try to use Tail BOV I think it don't have imitation yet. For HKS & Greddy immiation is close 99% only can tell by the logo itself. Ori brand logo are very sharp but immitation is fade abit but still very hard to tell if you don't have ori to compare.
mines998
1,048
149
663
The location you plant yr bov will affect the sound aswell.
avaultz
478
bro, have u ever try type-s imitations?
The Lexus RX line up is a success story in Malaysia with the RX 350, and with the newly introduced RX 270 luxury SUV, the story is about to get even more interesting.
The RX vehicles are the best selling in the Large Luxury SUV segment in Malaysia, equipped with premium features and coupled with stylish design and excellent performance, the Lexus RX models are a natural choice for those unwilling...
