87mm vg30 piston + 4D68 94mm crank + stock evo conrod, bolehkah?
gIGoN
327
jinkl, so u're saying that i could still use any aftermarket evo conrods but the only problem is the pistons?
should i get aftermarket pistons from the vg30 shelves? or if you know any aftermarket pistons which we could mix n match for this combo please let me know.
As an alternative, let's say if i were to install the CP stroker pistons (for 94mm application), could i compensate the metalgasket size, maybe we could -1mm from the gasket, eg: usin a 0.5, 0.8mm metalgaskets.
jinkl
4,623
376
3,183
u could buy custom pistons from wiseco or manley
try contacting this guy , Log masuk | Facebook
he is the one hooked me up with a custom wiseco
so u could just use a piston spec meant for 94mm stroker and just custom the piston pin location to move it down by 1mm , it should be much reliable than getting VG30 pistons n etc
11000RPM
954
2
3,018
Johor Bahru
Jinkl,
Have u encounter anyone using 4d68 conrod?
Its thicker but need bronze bushing, is it reliable?
According to my mech, it's much better.
The duratech conrod comes with bronze bushing isn't it?
I'm trying to save money lo, I'm trying to measure $/hp, kekekek...
gIGoN
327
anyone knows what's the stock vg30 piston height / comp height?
gIGoN
327
got it...it's 32mm so i believe i found the aftermarket combo which i would use.
1. Wiseco off the shelves VG30 pistons 87mm bore / 32mm comp height
2. Any off the shelves EVO conrods (Eagles, manley bla bla ) 150mm
3. 4D68 crank 93mm
Given that the std deck height is 229mm the setup above will yield to:
93mm/2 (crank) + 32mm (comp height) + 150mm (conrod) = 228.5mm which i would assume it would still be below the std deck and is safe to use wif a 1.5-1.8mm gasket.
I would say that if you're using an aftermarket 94mm crank, you could add in a thicker gasket, maybe 1.8mm - 2.0mm.
Sifus, correct me if i'm wrong somewhere hehe..
voiceofgod
10
on the 4G63 block. i tried it and the piston is slightly coming out of the block. a friend of mine asked me to modify the rod for a -6mm off set.
norick
111
39
87mm VG30 piston + 4D68 94mm Crank + 4D68 150mm Rod (same size as evo) will do..
Why ur's will over the block? Skimmed block before?
jinkl
4,623
376
3,183
modifying the rod for -6mm is the recipe for a total disaster on a turbo
---------- Post added at 12:04 PM ---------- 6 hour anti-bump limit - Previous post was at 12:03 PM ----------
this would work, bt its for 4g63 block or 64 ?
voiceofgod
10
its on 4G63 block. i was told its been done before and its a straight fit... any suggestion on how to get it done. uploaded is the 4d68 rod with the modification to fit the vg30piston.
and the 2nd picture show when fitted the piston coming out of the block
norick
111
39
No way... ur piston aldy told u the answer..
solution is either change ur crank to 94mm,
or change the piston to after mkt stroker piston..
Personally i suggest after mkt stroker forged piston..
Btw, ur 63 block is earlier batch(1,2,3) or newer batch(4-9)?
11000RPM
954
2
3,018
Johor Bahru
Some said 4d68 rods are too heavy, i personally found that it's much much more thicker than evo/vr4. What do you guys think?
---------- Post added at 07:58 AM ---------- 6 hour anti-bump limit - Previous post was at 07:57 AM ----------
Is the brass bush reliable?
im thinking for Mivec 2.0 kit from 4g93T turbo block ball to 2.0 stroker kit with mivec head high cam
but since now ppl telling me that use 4G94 mivec ? if not mistaken they are original mivec. but the problem is SOHC 2.0 4G94 ?
so do anyone here know that 4G94 mivec . same use extractor and inlet manifold? 4g94 with mivec head . 4g92 twin cam can ?
any one know any idea. or can explain for me tQ
