singapore had , i think jb also have.Do they have it in Malaysia? I thought only the USA have it?
But honda is also moving towards MAF on their new models. Thoughts?I used to have a FCON S fitted to my A32 VQ30 as I was only testing the unit. It was a pain to get the wiring right for fuel and ignition. Was able to get 6whp gain at the top end with a fully standard car.
What made alot of difference was if you use the FCON S with a pressure sensor and you tune the car using the pressure sensor. The end result was a much more responsive and lifely engine. Never liked the hot wire system as an air flow sensor. The pressure sensor is so much more responsive and better for small changes in air flow. You must have good resolution on your ECU as well and the HKS Fcon S resolution is quite good. I think more than emanage.
I tuned it with the FCON S and pressure sensor and the engine feels great. Don't understand why the OEMs all don't throw away all the air flow system and use pressure. Also less restiction on the intake as well when you want to make big power. That's something that Honda has always gotten right.
How much per can bro? Can get 1 can for me if you come to KL?singapore had , i think jb also have.
Its not the latest, latest. Just pop open any city vtec or fd2s you can find the maf.Hah Honda going to MAF? Why lah. I haven't check out the latest cars yet. Will check them out and see. These people going backwards. The only reason I can think is that the designer and manufacturer of the new ECUs design them with MAF so Honda have no choice. To them 99.9% of the people also wont know the diff between Pressure Sensor and MAF.
With the HKS Fcon S in the VQ30DE I didn't remover the MAF. F CON S has the ability to read the OE MAF or you can select an option mode to run additional pressure sensor which has to be manually installed in the car. So I added an additional pressure sensor to the F CON S and created a fuel and ignition map based on the pressure sensor and not the OE MAF.Its not the latest, latest. Just pop open any city vtec or fd2s you can find the maf.
I guess the 0.01% of the ppl like you and me knows the difference yah, hahaha ...
Btw , how in the world did you manage to delete the Maf in our fatty? If possible , I also dont want the maf to read our air/fuel mixture lah, its just toooo sensitive...
Can ajar-ajar abit ah..
Thx.:wavey:
I heard alot of people say that. Never tried it. Only have uses HKS and I like HKS F Con S and V pro.i don't trusted the e-damage,for na ok la. but for turbo it's a suck !! can damage ur engine..
