Moving Stock Clearance (Lelong Lelong) v.3
punktuichea
831
We are moving to new show room. so now we do stock clearance for all the item below. stock limited, 1st come 1st serve. thank you.
jasma meters (60mm) RM70 each:
boost sold out
volt x 1
vacuum sold out
rpm x 1
oil press x 1
oil temp x 2
water temp sold out
digital rpm x 1
5 inch big rpm + shift lamp x 1
rpm + shift lamp sold out
slim big RPM + push button shift lamp sold out
LED jasma meter gauge RM85 each:
5 inch led rpm meter with shift light sold out
3.75 inch led rpm meter with shift light x 1
led volt meter sold out
led rpm meter x 1
led vacuum meter sold out
led boost meter sold out
led water temp meter x 1
led oil temp meter x 1
led oil press meter x 1
digital volt meter x 1
52mm digital rpm meter sold out
autoguage RM70 each
boost sold out
volt sold out
vacuum sold out
rpm x 1
oil press x 1
oil temp x 1
water temp x1
JASMA 60MM GT-TYPE RM60 each
vacuum meter x 1
oil press meter sold out
oil temp meter x 1
water temp meter sold out
exhaust temp meter sold out
rpm meter sold out
air fuel ratio meter x 1
volts meter sold out
timers:
d1 turbo timer sold out
jasma sold out
I pocket timer sold out
HKS type zero turbo timer x 2 RM70 each
apexi turbo timer RM40 each
apexi turbo timer ( blue transparent casing ) blue light x 1
apexi turbo timer black casing, blue light x 2
apexi turbo timer black casing red light x 2
apexi transparent turbo timer sold out
defi boost meter x 2 RM150 each
pivot voltage stabilizer RM30 each
-pivot 82% volt stabilizer + DIGITAL volt meter ( 3pc wire ) sold out
-pivot 82% volt stabilizer NON digital x 5
-pivot 88% volt stabilizer ( 5pc wire ) sold out
-pivot 90% raizin volt stabilizer ( 5pc wire ) sold out
shift lamp : RM140 each
-jaw sold out
-violence x 2
pivot illumi starter button rm25 each sold out
racing type starter switch 1 switch 1 button RM40 sold out
racing type starter switch 2 switches 1 button x 1 RM50
racing type starter switch 3 switches 1 button x 1 RM55
oil catch tank :
normal oil catch tank x 1 RM70
greddy oil catch tank x 1 RM90
cusco fuel catch tank x 2 RM70
d1 oil catch tank x 1 RM60
simolta oil catch tank sold out
adjustable cam pulley RM100 per pcs:
MITSUBISHI 4G91, 4G92, 4G93 , 4G93T (TWIN CAM) WIRA 1.8 sold out
KENARI ,KELISA x 2
MIRA L2 x 1
PROTON ( CAMPRO ) GEN2,BLM,NEO,PERSONA,WAJA x 1
EVO 1-8, VR4 (RM200) sold out
WAJA 1.6 (4G18) x 1
WIRA 1.6 (SOHC) x 1
WIRA 1.3,1.5,ISWARA ,SAGA, SATRIA 1.3 x 1
LIGHTEN CRANK PULLEY RM110 per pcs
vr4,evo1/2/3,perdana (6a12) oem size sold out
wira 1.3/1.5,saga,iswara,colt,mirage,lancer 85-00 (1.3/1.5 sohc) 1in smaller than oem x 1
wira 1.3/1.5,saga,iswara,colt,mirage,lancer 85-00 (1.3/1.5 sohc) oem size x 1
myvi,avanza,kembara oem size sold out
waja 2001 sohc 1.6/1.8 (4g18) oem size x 1
gen2 campro,waja campro 2003,saga blm(new saga),persona,satria neo oem size sold out
wira 1.3/1.5(svdo),wira special edition injection 2001-2008 oem size sold out
mitsubishi lancer 4g91,4g92,4g93, perdana old,putra,gti,4g93T gsr oem size x 1
kenari , kelisa & viva crank pulley x 1
waja 2003 crank pulley ( big shaft ) x 2
Project S saxo stanless steel drop in high flow AIR FILTER RM110 per pcs:
CIVIC FD 1.8 X 1
CIVIC FD 2.0 X 1
CIVIC SR4 X 1
CRV 95-01/EK/SO4 X 1
JAZZ 03/CITY OLD X 1
VIOS 03' sold out
VIOS 07' X 1
WAJA/WIRA 1.6 1.8 sold out
SAGA BLM X 2
GEN-2 sold out
PERSONA sold out
MYVI 1.3 X 2
VIVA sold out
KENARI KELISA X 3
NISSAN ALL MODEL sold out
racing teflon brake hose RM85 per set
JASMA civic ej/ek racing taflon brake hose 4pcs x 1
JASMA civic eg racing taflon brake hose 4pcs x 1
JASMA wira racing taflon brake hose 4pcs sold out
JASMA waja/gen2 racing taflon brake hose 4pcs x 1
JASMA kancil/L2 racing taflon brake hose 4pcs x 1
HKS super flow (musroom) open pod air filter x 6 RM25
HKS super filter x 20pcs RM10
oil cooler 13 row RM130
oil cooler 15 row RM150
*kindly sms 016-6638205 for more details.(sms only).thank you.
punktuichea
831
grab it while stock last... its time for u to buy in bulk. only got one chance. its real cheap!!!
punktuichea
831
all pm replied.if i missed any please let me know.thank you.
punktuichea
831
selling fast...all pm and sms replied. if i missed any1 please let me know.thank you.
punktuichea
831
status update...a lot sold out...grab it while last...thank you.
punktuichea
831
you got pm. closing at end of january please make your step faster!!!
HaZaRd
143
5
bro... Greddy oil catch tank still available? How do I collect stuff? thanx. :ridinghorse:
This product is being introduced by my mechanic. I don't know what is the market price of this product. Father bought it. It is quite effective.
First, this is use on carburetors and there are a lot of this kinda product in the market even for fuel injection cars.
