4g67 turbo..
speed2horizon
2,798
334
1,683
update...got a td05-20g instead :)
Hope it can get me to 300whp :P
HAHA... Actually a standard E3 td05 16G is rated to produce 365-385HP boosting at 22psi(1.6bar). Minus 20% transmission lost, u'll get around 310WHP. Rule of thumb...
However, at what cfm..? u have to refer to the compressor mapping and do some RPM calculation.
It's not the turbo anymore... It's whether ur turbo spin fast enough to induce sufficient pressure. Please show me ur calculation when u say 1.5mm metal head gasket reduce compression ratio to 8.5:1...
Give u a tip.
Increment of exhaust valve lift will sustain the exhaust flow. Bigger capacity increase the exhaust flow with lower rpm.
speed2horizon
2,798
334
1,683
e3 td05 stock standard will produce 310whp ?
The Turbo is rated to support 365hp-385hp... So, how much it's able to deliver to your wheel depends on how much friction from ur pistons to your wheel.
Engine balance
Bearings
Transmission
Ball joint
here and there
+-20%.
If automatic +-30%.
Losses are purely unproven calculation. Just a rough estimation.
teztozterone
381
Give u a tip.
Thanks for the tip bro :) So the exhaust valve lift will reduce lag?
My 20G was done by SpeedSpin, but I didnt get the CFM from them.
The compression ratio 8.5:1 is just a guess...I'm not really sure :P
But I do know that I got 170-180psi across the 4 pistons ;)
speed2horizon
2,798
334
1,683
They are rated for 365-385HP. But again, wether all the power is going to be able to be delivered to the wheel is another story.
U can say that... When u launched ur wheels, and u'll notice the boost able to sustain and climbs faster..
20g compressor map, just google it.
170-180psi..? U mean the pressure u achieve from the compression test.?
teztozterone
381
yup...those are compression test results
ok bro, will do the exhaust valve lifts ;)
Thanks a lot.
speed2horizon
2,798
334
1,683
Thanks a lot.
Exhaust valve lift can only achieved with cams change
---------- Post added at 04:02 PM ---------- 6 hour anti-bump limit - Previous post was at 03:09 PM ----------
Thanks a lot.
Exhaust valve lift can only achieved with cams change... But do remember, when cam lift is too high, idle will need to set high too... else, mati engine
zamans98
128
3,018
Can someone please tell me, what is the reason for spending money + time + headache + more money if phailed for this Rojak setup?
why not angkat direct EVO2/3 engine? Standard one good enough.
owndferra
233
jb
different people,different interest..
some people like the easy way, some people like the adventurous way...
they all got their own reason by choosing to use this engine..
speed2horizon
2,798
334
1,683
Reason is simple. A 4G67 short block configuration is same as VR4. 6 bolts crank. The contruction is more solid, esspecially on the rods.
2nd, JPJ endorsement could not be done...
3rdly, want to do it the legal way instead of paying the under table money to the authority and contributes nothing to the country income...
4thly, punching number if accident and then kena kantoi, no insurance claim will be provided.
5thly, Even if u got pass the JPJ on the endorsement... When big blocks, they can still take ur car back to question you...
6thly, The project rarely fail. It's proven to work in Australia, NZ, USA, Thailand... unless u did it with a bad mechanic.
The definition of good enough can be different for different individual....
I had E3 complete transplant in my Satria... But I'm back to 4G92BOT. Call me stupid if u like...
Ur question seems like, Why hondata when there's haltech/microtech in the market... why reading novels when there's movie for that novel, why letter when there's email...
The answer is... More fun, excitement, and good learning experience... Just different... no point insulting...
owndferra
233
jb
agreed.......brilliant answer...
mlebuangetmetupliket
5
jakarta
well......
after seriuosly read u guys posts... i finally inducted my 4G67 with VR4 block & turbo
yes... i use 4g67 head combined with vr4 block.. :proud:
1. vr4 block w/ complete pistons etc.
2. turbo TD05H set include manifold etc.
3. unichip dastek type Q+
4. Intercooler
5. Injector (add 2 pcs more)
6. Piping... etc
7. USD 4000 (ofcourse :bawling:)
Standar --- 140 HP
P&P N/A with unichip dastek type A --- 158 HP
Force induction with turbo --- 283 HP
13,1 sec @ 402M
bebolagalas T
733
29
Bro U Need to search or google the Comp Map OF 20g Wheel to get the CFM ...there's no turboshop sell the cfm bro..:love:
cfm is cubic feet per minute bro...
Hye ppl,
I have been having this urge to fix roll cage on my satria.
My doubt is, is it illegal and would the authrority pinalize me for this.
Would my insurance be still valid just incase of a accident.
Please share your thought's and exp.
Thanks and happy motoring.
