Car shaking when engaging 1st gear
fevernova_xx
40
Hi,
I just installed exedy semi-racing single plate clutch to my Satria GTI BOT. Before this I'm using standard clutch which is slipping like hell when flooring. Is it normal or not when engaging the 1st gear, the car is terribly shaking. I have to increase more rpm to reduce the vibration. thought this is normal because I never tried racing clutch before. Thanks in advance.
BLANk
1,750
6,757
Sardine
www.zerotohundred.com
did ur mech skim the flywheel before install the clutch & gearbox?
seems like ur car flywheel surface where the clutch friction material & the flywheel contact warped/uneven...
try to drive a few days let it seasoning 1st...if u are lucky enough it will gone after few days of seasoning & if problem still exist then have to take out the flywheel for skim...
maybe there was some oil stain on the clutch plate/flywheel kena during installation???
or try running in your clutch first and then see for a few weeks..
:adore:
szeeonn
131
10
Mounting lah dude
or the BOT not install properly , something kena Body / chassis / Cross member
check it clearly
i tot all racing clutches (3puck & above) should feel like that....
no lah...mostly from my rally car experience its because of the clutch plate/flywheel kena oil stain (or flywheel not cleaned properly) making the clutch biting point lompat2 coz got slippage at certain area (oil stain) and bite back at clean area..... :adore:
when full clutch release sure grip all if not thats not race/high performance clutch unit :biggrin:
*was this fit the TS description of "shaking" ???? :hmmmm:
nic1213
325
5
3,018
peejay
Mounting lah dude
check it clearly
hmm... why would it be mounting? or BOT installation can make the car shake? mind to clarify bro?
hachiroku clan
633
73
hmm mine shakes when in 2nd and 3rd gear when driving very slow like in a traffic jam..
g/box mounting changed as well (replaced oem clutch 3 months ago)..
what could be the cause?
kumar22mostwanted
1,562
152
HELL!!!
yeah i am also faced with this problem where car shakes violently in 1,2 or 3rd gear at low rpm's when engaging the gear
anyone care to chime in???:listen:
fevernova_xx
40
appreaciate all the replies.. according to my tuner, the vibration is perfectly normal. The more pucks of the clutch plate, the less vibration it will produce. I have to sacrifice the comfortness of standard clutch for the sake of more power, unless i'm willing to buy more expensive clutch plate.. after 2 weeks, i have used to the stiffness and the shaking. The vibration only in 1st gear only, only need to rev up some more, no problem. Going to dyno again to see how much horsies gained
shiroitenshi
3,676
170
sounds like clutch chatter. Stock engine mounts loose?
Even if set up properly, racing clutch will have chatter. That's why race car use harder engine bushes. But most people here using semi racing or light single plates so car shaking is a bit extreme. Usually feel at pedal only, not entire car. .
The exedy single plate is quite streetable, so it would be extreme for the car to shake. try open the hood, see how the engine reacts when you release the clutch in first. If the engine rocks excessively in the mounts, you probably have one engine mounting loose/rosak. Even loose CV can make the car vibrate. If not. Some other problem, and probably problem with the clutch.
Other explanations already given by other forummers like improper install is also possible, but since you've never used racing clutch before, hard to say what kind of vibration is bad, and what is normal.
Personally, for road driven cars i'd rather go organic than full out race clutch, imo. Better clutch feel.
If using a new racing clutch, should always break it in first. If use second hand, dunno la. Sometimes the 2nd hand racing clutch I see already burnout, yet people still buy, lol.
E3newbie
291
15
Can you please elaborate what kind of shaking you are experiencing? Is it like jerking, like the clutch biting then whole car jerking in bursts? If so then I think its normal when new, should get better after you break it in.
kumar22mostwanted
1,562
152
HELL!!!
yeah mine is like that
when i engage a gear then the car is jerking rapidly in bursts :banghead:
but my clutch is about 1 year old :hmmm:
E3newbie
291
15
It should only occur when at the biting point. If its jerking when clutch is fully engaged then its definatelysomething wrong man..
Hi,
My gf is driving a 1989 Proton Saga 1.5 with magma engine. recently we wanted to paint the car, so myself with my manly feeling brought the car and did some modification. below listed is what i have added to the car.
1.> K&N Style air intake
2.> This fuel thing that looks like this <<||||||>> which i bought at brothers that cost RM 58 which is suppose to save fuel. I think it is called a fuel/air compressor.
3.> Bosch Super 4 spark plugs
4.> complete Race exhaust system.
the...
