D1SPEC Multi Function Timer (5 in 1), Brand new RPM/Shift Lamp/Turbo/Volt/Auto
Cola
Selangor
Item(s):D1SPEC Multi Function Timer (5 in 1)
Package includes:
• Auto Timer
• Shift Lamp
• Wiring Harness
• 1 Year Warranty Card
• User's manual and Installation Guide
Market price RM299
Get it now at Dealer Price:RM2xx
Warranty:1 Year
Dealing method: Postage (POS LAJU) / COD
Location of seller:Shah Alam/Subang/Klang
Installation can be arranged. Call/SMS me
Contact method/details:012-6527100 ([email protected]) MSN MESSENGER
Age of item:Brand new
D1-SPEC Latest 5 in 1 Multi Auto Timer contains five function:
•RPM Meter
•Shift Lamp
•Turbo Timer
•Auto Timer
•Volt Meter
Operation of Turbo Timer: -
1.After the vehicle engine started, the relay module will be activated to output power to your vehicle. Hence the engine will remain on for a period even you turn off the ignition.
2.The turbo timer will function only when your hand-brake is engaged. Else, the system will release the relay and your vehicle's engine stop immediately.
3.There are two method to set your Turbo Timer period: Manual and Auto
Operation of RPM Meter: -
1.This function shows your vehicle RPM reading in 4 digits LED Display
2.If the pink wire is not connected correctly, the display will either show a wrong reading or the alphabet "RPM"
3.You'll need to set the cylinder number of your vehicle (TP1 ~ TP5), else the RPM reading will not display correctly
4.If all 5 cylinder can't match your vehicle, you can still use fine tune option to minor adjust the reading. First you must choose the best fits cylinder type and then press "SEC" or "MIN" button fine tune
•TP1 - 6 Cylinders
•TP2 - 4 Cylinders
•TP3 - 4 Cylinders (turbo)
•TP4 - 3 Cylinders (carburetor)
•TP5 - 3 Cylinders (injection)
Operation of Volt Meter: -1.The function basically just show your battery voltage level
2.It will give an audible warning when the battery voltage is below 11.8v
Operation of Shift Lamp: -
1.When your vehicle RPM is higher than the preset value (default: 5000), the device will flash the shift lamp to give indication
xand said:
bump for nice item!
are all the sensors included (RPM sensor, battery voltage sensor and auto-timer sensor)?
yes bro, all included.
installation bro? can u tell me where to install that item? and how much?
nice item bro..free bump!:cyclops:
contact me at 012-6527100 (Larry)
for more details on the installation
pm me best price + installation plz.....thnx
pm me the price..... and ur location.....contact number and name thx
call me for immediate response
014-6250930 (Larry)
bro wanna ask still got the product anot? pls pm me the best price larrr including install thanks
