ZTH MINI Club!
  • Thread starter skyline86
  • Start date
  • Replies 3K
  • Views 276K
Yo guys,
Nice to see all of you are active esp Sureshn, fastclubman you guys... Sureshn your engine got free fixing? since I know you are a great part time mechanic, if so I may consider, hahaha.
By the way, I would like to know is anyone here having "Italian Job" which is back to 60's ? If have it can borrow me to burn or anyone could tell me where can I get it, I tried ebay but can't get. Pls contact me at 0123436818 if you have.
Here are some interesting links, hope you guys enjoy:
Italian Job Trailer:
YouTube - The Italian Job trailer
Part 1:
YouTube - The Italian Job - Part 1 of 2
Part 2:
YouTube - The Italian Job - Part 2 of 2
Part 2 is quite interesting :D
Regards,
Koh
skyline, the founder of the thread! it's better still to see you still active.
free fixing, huh? if you want a VERY long term project, then sure! ;) i work so so slow ... that's why it took me 2 yrs to put Mokey on the road.
original italian job - i have it. sms me ur address. i'll burn it and put it in the post.
0126535782
'semputting' - apt word to describe it! my Mokey is beginning to suffer from that too. but once i run for 5 kms or more, semputting is gone. I think the carb is sticking.
fastclubman, you should be able to tell me if that is correct diagnosis. what do u think?
no offence but its a YRV engine Max. output 128.8 PS (127.0 bhp) (94.7 kW)
@6400 rpm
Max. torque 170.0 Nm (125 lbft) (17.3 kgm)
@3200 rpm
urs a 1400 ... just around 80 - 100 bhp... its like 30 more bhp for the YRV.. :shades_smile:
mini kuning: well there's nothing wrong with hoping bro... i've fragged quite a few more powerfull cars when i used to drag with my old DC5.
If i lost by a few meters to the YRV then i would still be ok... losing coz my engine isn't performing the way i want to is another thing all together
gharith,
U need to get the car fine tuned. Spark plug heat range, using the correct needle and springs for the HIF, correct idle mixture and ignition timing are all essential areas for obtaining the optimum and reliable performance on the A series. This is an art which require fine balancing and skill, which is unfortunately getting lesser to find these days. Thats why i still keep one on my favorite fast road cam and a HIF carb which was jetted for that application. Its the sweetest A series engine i have had, not to mention the most reliable too!
sureshn,
i guess you must be starting up the car (to warm it up) occassionally but not really driving it. Usually its the idle mixture which is rich causing carbon deposits to build up on your plugs. With 5 km of driving the deposits are all cleared up which makes the car to run smoother without 'semputting'. If the carb sticking due to lack of dashpot oil then you will have this consistently, even after 5 km or so of driving. Just hook up to a CO meter and adjust the idle mixture screw at the back of the carb. Should do the trick unless there is a leak somewhere!
minikuning,
the advantage the YRV kelisa has is traction compared to the mini. Once you are pushing about 100+ hp on the mini, wheelspin is a big issue, even in dry conditions. 1st gear on my mini is hopeless on mine due to wheelspin and this is with using 175-50-13 tyre combination and a 3.1 final drive!
just my 2 cents
fastclubman
Lol i'm getting wheelspin even on 2nd gear... currently running 12" and 3.1 final drive as well.
Maybe i should get fatter tires and move back to 13"
hahahaha...
maybe you should represent me.. having a rematch next week against that Kelissa :P
or maybe i should just move to webers once and for all...
hahahha
i will let u do the battle! i just dont know when i iwll have time to get it back to HH for a tune up!
Gathering / TT'ss
People.... its been along time since we have been having a TT .... so lets have one
this FRIDAY .... n i also will ill be coming down to SHELL LDP opposite eastin on
friday 1/JUNE/07(its i nice date) with 2 -3
mini's from cyberjaya if everything goes to plan.....Dont let the mini spirit die...hehe....
ill be taking pictures n stuff n plus jalan jalan pusing KL if condition permits.
If u dont have ur mini running .... just come down by in ur normal car:confused_smile: , me too still
having problems with my mini but at least there is a crowd there and we can chat,
kongsi masalah n hang around. Hope to you minians n zthians who wish to come n
chill, its ok .. we minians r cool with it..hahaha... really miss does mini
days..
drats... the day that you set the TT I won't be in the country :(
I'll be back next friday though :D
guys...
i have a mini 1000cc and recently upgraded the car by fixing air cond...but that's where the problem starts... seems like there's a lot of squeaking sound from the air cond and i have tried send it to mechanic to fix numerous times without success... definitely confirm the squeaking sound is from the air cond cause when i turn off the air cond, the sound is gone...
should be from the air cond belt... but how come the problem can't be fixed by the mechanic? anyone with a known problem/solution can help? thanks!
you might have belting problems if the noise comes from the engine everytime you
press the accelerator. Try to tighten the belting or replace it. If its a whinning sound
something like a turbine sound it means its ur compressor bearing. Other than that if
might just be your air con blower itself.. check fan that brings in air, it might have
something stuck there like leaves...etc2.
Mini Stuffs for sale
10 inch disk brake
Magnolia Speedometre 3 dials (the tye behid steering)
Chrome Grill with Spotlights
call 012 657 9878, i dont visit here often.
hey guys!
its been ages.. ill be back frm london soon..
so i'll be seeing u guys around soon..when i get back lol...
cheers!
so how was the TT / convoy?
i'm back in kl now :) so when are we having another get together?
dude.... there were only 3 minis including mine... n all are from the same college. Its
cool though we went to NZ to have char kuey teow n drinks then had a photoshoot
at a projet nearby ... its cool but really hope that more minis could come and plus our
lepak spot got stollen by japanese car club i think so because there were silvias,
skyline,cefiro parked around me... damn its crazy so i ran off to the back of shell.
So this FRIDAY nite is on.. i hope more minis would come n make the mini scene rock...
FRIDAy !! 10 - 11 pm
any suggestions where to go ?
IM ON!! this friday i'm as free as can be :)
i'd rather meet up then go convoy to places ahahah... i guess i got bored of the mamak thing
