http://i642.photobucket.com/albums/uu143/zdeadlyz/pulse.jpg
http://i642.photobucket.com/albums/uu143/zdeadlyz/impulse.jpg
Item: USED Hot Inazma Pulse (2 Unit) RED & BLUE
Price: RM300 (New selling RM670). BLUE SOLD. RED SOLD.
Condition: 100% working. Used less than 1 year.
Item: USED Inazma Pulse Blue
Price: RM280nett + Free Shipping
Condition: 100% working. Used > 1 year.
Picture:
http://i642.photobucket.com/albums/uu143/zdeadlyz/IP3.jpg
Warranty: Personal warranty 1 month
Dealing method: COD/Postage.
Contact: 017 690 5979
Email: [email protected]
Inazma Pulse
The electronic noise generated by the ignition system is said to be the strongest among several other electronic noise found in a vehicle. These interferences of electronic noise can cause difficulty to your vehicle's electronic equipment. The Inazma Pulse can be used to eliminate the electronic noise and increase the effects of ground returning to the negative post of your battery. This will prevent glitch and unwanted noise coming from electrical device and also avoids functional decline of each device. With the Inazma Pulse, the potential of all electrical components of your vehicle can be extracted as much as possible. Installation of the Inazma Pulse is easy. One cable is grounded to the negative terminal of the battery, and the other two cables are grounded at the radiator and alternator.The Inazma Pulse is a supplement to the negative side of electrical circulation, whereas the Hot InaZma/Hyper Voltage System increases the efficiency of electrical circulation on the positive side.
Effect of Inazma Pulse
With InaZma Pulse, the electrical noise generated from your car's ignition system within the frequency band from 750rpm until 6000rpm is absorbed and combustion efficiency of your vehicle is increased. As a result, you can expect various positive effects on your vehicle such as increased horsepower and better torque, increased gas mileage, reduced audio noises, stabilizing idling, brighter headlight illumination, and reduced gas emission.
Dyno Chart
http://i642.photobucket.com/albums/uu143/zdeadlyz/pulsedyno.gif
http://i642.photobucket.com/albums/uu143/zdeadlyz/pulsemill.gif
Picture:
Inazma Pulse
Dyno Chart
