- Joined
- Jan 18, 2006
- Messages
- 7,962
- Points
- 1,638
Welcome to AfterTwelve E-Garage!!!
We do shipping internationally / COD / Credit card accepted.
We provide installation and painting as well.
Some item's price quoted below including installation or painting.Please take note.
Any kit that you are interested but not listed here, please contact us.
VISIT: AfterTwelve E-Garage
For order/enquiry, please contact JACK 012.312.7113.
Promotion:
Service / Maintain your car at After12 Motorsports and get more discount!!!
TORCO Gear Oil - SGO / RGO / Limited Slip
TORCO SGO Gear Oil RM105.00 - RM110.00
Product Description
SGO is designed to maximize power efficiency and provide the highest level of gear protection under the most severe speed and load conditions. It is formulated using a combination of Group IV/V synthetic base oil chemistries and additive technologies providing high shear resistance and 4-5 times the film strength of conventional oils. This combination of base oils and extreme pressure chemistries offer superior wear protection, improved power throughput, longer component life and prevents rust and oxidation
Features & Benefits
- 100% Synthetic Formula
- Superior shock load and wear protection
- Increases power throughput
- Reduces operating temperatures
- A balanced concentration of race proven chemistries
Typical Uses
SAE 75W-90 RM105.00
Recommended for use in differentials, transmissions and transfer cases requiring an SAE 70W90, 75W90, 80W90 or 90 GL-5 or GL-6 rated gear oil. Used in all forms of racing and performance street applications. Highly recommended to optimize power efficiency and extended drain intervals.
SAE 75W-140 RM110.00
Recommended for use in differentials, transmissions and transfer cases requiring an SAE 75W140, 80W140 or 85W140 GL-5 or GL-6 rated gear oil. Used in all forms of racing and performance street applications. Highly recommended in extreme loads or continuous high temperature applications.
TORCO RGO Gear Oil RM60.00
Product Description
RGO is formulated using highly refined petroleum base stocks and select additive systems to improve gear protection and high temperature stability. Special high adhesion polymers focus on shear stability, thermal stability and high shock load protection. RGO carries a higher concentration of extreme pressure additives, anti-oxidation, anti-corrosion and anti-foam to prevent fluid degradation and extend life of all drive components.
Features & Benefits
- Premium racing grade formula
- Excellent thermal and shear stability
- High shock load and extreme pressure chemistry
- Extends life of all drive components
TORCO Limited Slip RM40.00
Product Description
Torco Limited Slip Additives are formulated for use in limited-slip and posi-traction differentials to reduce hypoid gear noise and chatter. The formulation of Torco Limited Slip Additives modify clutch plate friction for applying and releasing clutch plates.
Features & Benefits
- Eliminates gear noise and clutch chatter
- Improves clutch engagement
Promotion:
Product Description
Features & Benefits
Typical Uses
SAE 75W-90 RM105.00
Product Description
Features & Benefits
Product Description
Features & Benefits
