Elf Molygraphite 10W30 Engine Oil (3 litres)
Key Features
-Viscosity rating of 10W30.
-Provide excellent thermal and oxidation stability.
-Reinforced with dispersing and detergent properties.
-Superior anti-wear properties.
-High shear stability ... providing optimum lubrication at low and high temperature.
-Suitable for all gasoline/petrol engine from 600 cc.
Benefits
-Noticeable decrease in wear and tear due to cold start, especially in the morning.
-Better lubrication at all times increases engine efficiency, better fuel consumption.
-Maintain engine in silent operating condition.
-Added protection from graphite and molybdenum provide better protection and increase reliability of moving parts.
-Keeps engine in clean under all operating conditions.
RM55
Elf Molygraphite 15W50 5L
-Exclusive lubrication technology incoporates solid lubricants of graphite and molydenum disulphide, ensures your engine stays clean and operates at maximum efficiency, resulting in longer engine life.
-Suitable for all gasoline/petrol engines.
-API:SL.
RM95
ELF Molygraphite 15W50 4L
-API:SL.
RM80
ELF SYNTHETIC PRO 10W50
-The latest in additive technology for very high performance gasoline engines .
-Exceptional cold fluidity with low pour point - instant starting and lubrication even in low temperatures.
-Cleaner engine and longer lubrication life.
-Prevents formation of deposits, varnish, sludge and corrosion.
-4 litres.
RM165
ELF MAX BOOSTER
2-in-1 octane booster and fuel injector cleaner!
• Restores engine's power performance.
• Maintains cleanliness of fuel system and protects against corrosion and rust formation.
• Cleans deposits on fuel injector for better and more efficient combustion.
• Reduces pollutant emission to the environment.
• One measure treats up to 150 litres of petrol or use once a month for normal usage.
• 250ml.
RM24
Elf Grapholia for Diesel Engine 5L
Elf Grapholia is recommended for Diesel engines operating under severe service. It meets and exceeds the following classifications :-
*API : CF-4 / SG
*ACEA : E2-96 (CCMC : D4)
*US Army : MIL-L-2104E
It also meets the requirements of most of engine manufacturers and approved by :-
*MERCEDES BENZ : Sheet 228.1
*VOLVO : VDS specification
*MAN : 271 specification
*DETROIT DIESEL ALLISON : C4 specification
*CATERPILLAR : TO2 specification
Features
-Outstanding detergency to prevent sludge formation
-Outstanding dispersancy to avoid the agglomeration of particles originated from combustion
-very high alkalinity reserve to nuetralize acid products from combustion
-superior anti-wear and anti-corrosion capability
-excellent thermal and oxidation stability
-excellent protection against bore polishing
API: CF-4 Classification.
CF-4 for High Performance Diesel Engine
This category was adopted in 1990 and describes lubricants for use in high speed, four-stroke diesel engines. API CF-4 lubricants provide an improved control of oil consumption, ring groove and piston deposits.
RM88
Elf Moto 2T Power 1L
Synthetic-fortified lubricant for high performance two-stroke motorcycle engines. Specially formulated to protect the environment by reducing smoke level while maintaining the best performance of engines.
-High protection against wear.
-Superior thermal stability and anti-oxidation capacity.
-High protection against ring sticking and spark plug whiskering.
-Self mixing with leaded and unleaded petrol. Meets or exceeds the following requirements :
API TC (American Petroleum Institute)
JASO FB (Japan Automobile Standards Organization)
ISO GB (International Organization for Standardization)
RM17
Elf Moto 4T Power 1L
Super multigrade (20W50) lubricant for four-stroke motorcycle engines. Suitable for all four-stroke motorcycle engines. Proven adaptation to several operating conditions - city traffic, long distance ride, etc.
-Very good detergent and dispersant capabilities, enhances engine cleanliness and engine output.
-Excellent anti-foam characteristics.
-Enhanced anti-wear ability and exceptional thermal stability.
-Contains specially selected additives for efficient protection against high temperature seizure and spark plug fouling.
fully compatible with leaded or unleaded petrol.
Meets of exceeds API SF/CC specification.
RM17
Thanks for viewing
Key Features
Benefits
RM55
-API:SL.
RM95
-API:SL.
RM80
-4 litres.
RM165
ELF MAX BOOSTER
• 250ml.
RM24
*API : CF-4 / SG
Features
RM88
RM17
RM17
Thanks for viewing
