Comanche
Banned
DESCRIPTION:
- Modern top class low-friction engine oil for all-season use in gasoline and diesel engines without diesel particulate filters (DPF). The combination of innovative base oils – based on synthesis technology and the latest additive technology – guarantees an engine oil that reduces oil and fuel consumption and that ensures fast lubrication of the engine. Depending on the manufacturer instructions, oil change intervals of up to 40,000 km are possible.
PROPERTIES:
- smooth engine running
- rapid oil delivery at low temperatures
- optimum oil pressure at all engine speeds
- high lubrication reliability at high and low temperatures
- high shear and ageing stability
- saves petrol and reduces pollutant emission
- long engine service life due to high level of protection against wear
- outstanding engine cleanliness
- tested with catalytic converters and performance proved with turbochargers
- miscible and compatible with commercially-available engine oils.
Specifications / Approvals:
API SN/CF
ACEA A3-08/B4-08
BMW Longlife-01
MB-Approval 229.5
Porsche A40
Renault RN 0700, 0710
VW 502 00/505 00
LIQUI MOLY also recommends this product for vehicles for which the following specifications are required:
Opel GM LL-B025
Fiat 9.55535-H2, 9.55535-M2, 9.55535-N2
Peugeot/Citroen (PSA) B71 2294, B71 2296
TECHNICAL DATA:
Viscosity class : 5W-40
Density at 15 °C : 0.855 g/cm³
Viscosity at 40 °C : 90.0 mm²/s
Viscosity at 100 °C : 14.7 mm²/s
Viscosity index : 171
Flash point : 236 °C
Pour point : -33 °C
ASTM colour : L4.0
Ash, sulphate : 1.2 g/100 g
PROPERTIES:
API SN/CF
ACEA A3-08/B4-08
BMW Longlife-01
MB-Approval 229.5
Porsche A40
VW 502 00/505 00
Opel GM LL-B025
TECHNICAL DATA:
Pour point : -33 °C
ASTM colour : L4.0
