Turbochargers-T3/T4,TD05H,GT45
dre42
7,000 RPM
This here are brand new items..All item are available to view before purchase.
Brand new high performance turbocharger from redline garage
T3/T4 - RM1800
Specifications:
1) Trim-turbine: .72
2) Trim-compressor: .57
3) A/R turbine: .63
4) A/R compressor: .50
5) 550 Horsepower
TDO5 16G - RM2000
TD05H -16g ( WATER COOLING )- Mitsubishi EVO ,water cooling , twin fins-16g internal wastegate,
TD05H is twin fins compressor wheel . Flow range is 0.05-0.22 kg/s , work for 50-130kw engine. ( especially for EVO III )
UP TO 350 HORSEPOWER
GT45 - RM2300
Specifications:
1) Inlet (exducer / hot side) T-4 flange: 70.1 x 82.55mm (2.76 x 3.25")
2) A/R 1.05 exducer
3) A/R 0.66 compressor
4) Cooling / lubrication oil
5) Outlet (exducer / hot side): 4.25" V-band
6) Inlet (compressor / cold side): Φ109mm (4.25")
7) Outlet (compressor / cold side): Φ86mm (3.38")
8) Compressor major diameter: Φ98mm
9) Weight: 14.5kg
10)850-Horsepower
Please view http://www.redzoneconnection.com for those turbo specification
[email protected]
CONTACT 012-2698554(KL,PJ)
12 months warranty against faulty workmanship
it's brand new...not recon,not used
i am driving the CK lancer GSR. and using TD04L. i wish to replace my TD04L with a new TD04L. what i know is my td04L is totally different side with wrx td04L. so how much is it or do u have it? maybe u wanna check and let me know? i want a replacement, meaning , i dont wish to tune, wield any exhaust, just direct replacement. my car model is CM5A lancer GSR. pls let me know. =)
we don't have any TD04L..will try to source that out
Interested Parties May Call 012-2698554 (KL,PJ AREA)
jOHOR Area Please call 013 7256390
bro...ur T3 got arculator or not? u hv sell any banana for GSR? hv pic on it?
there is no such thing as .55 trim t3/t4
do correct them , t04e wheels come in 46trim , 50 trim , 57trim
mate..that's too big for VR4 unless your vr4 has big h/p.. it suit rotary,supra V8 or any big cc..
Bro..... i'm using Toyota 1G-GTE engine !!! Can T3/T4 turbine suit for my engine ???
hi..yes it will fit a 1G-GTE just fine
.......................bump..................
hi....how about 4age 16v with T3/T4 ? thx...
T3/T4 is too laggy for a 4A-GE, especially if you want to drift with it.. if not it will be sweet..
