http://www.tools4solidsurface.com/files/images/thumbs/t_19892.jpg
http://www.youtube.com/watch?v=gPCoyr1GSRA&NR=1
STRIKE HOLD CLEANER - DRY LUBRICANT - PROTECTANT - much much much better than WD40 etc
http://www.strike-hold.com
trusted & used by military around the world include ATM malaysia for superior lubrication & protection of their weaponry...
Strike-Hold is a fast acting penetrant that immediately cuts through dirt, rust, carbon and and scale to quickly get in to metal parts that have become frozen by or encrusted with corrosion and oxidation. This product provides a long-lasting dry lubricant , which reduces friction and will not build up or become brittle. As a demoisturant Strike-Hold helps dry out wet electrical gears and other water sensitive parts. As a protectant, this product provides a shiels-like film against the effects of moisture and corrosion, even against salt water while actually repelling sand, dirt and dust. Strike-Hold contains no CFC's or other ozone depleting substances. Strike0Hold is non-flammable and ver safe to use as directed.
Electrical/Communications:
Strike-Hold has an extremely high dielectric strength and will actually improve performance by cleaning and protecting contacts and internal parts, including circuitry and connections. This product will not harm commonly associated materials such as rubber, most plastics and wood finishes.
Marine/Auto Maintenance
Strike-Hold is highly effective for all marine applications, vehicles, R/C's and trailers. It quickly penetrates and removes existing rust and corrosion from all metal surfaces while a dry lubricating protective shield remains that will significantly reduce wear and malfunction caused by friction and the damaging effects of moisture. Strike-Hold will not wash off with water...even Salt Water! Highly rusted and/or frozen bolts are loosened quickly and easily. Use it on anything subject to rust or corrosion, including all of your marine hardware & fittings , rigging, electrical and navigational equipment & connections, engines, trailer wiring and lighting.
only RM59.00 for total protection....
call/sms 0133023774
location setapak/hulu klang
YOUTUBE
http://www.youtube.com/watch?v=0GWH1aiiEdM&feature=related
just google 'StrikeHold" u can get more reviews!!!
call/sms 0133023774
YOUTUBE
