ST Suspensions ST XA (adjustable dampers) For many models
Espada Motors
Espada Motors Sdn. Bhd. is located in the heart of Bandar Sunway whereby we are operating from an industrial lot where we provide A ONE STOP SOLUTION to cater to all our customer's expectations. We are passionate about cars and we specialize in Continental, Japanese and Classic Cars. Equipped with the latest diagnostics such as BMW GT2, Star Diagnostics, Piwis 2, and others which allows us to diagnose, code and calibrate all faults accurately. Our scope of work includes engine rebuild, diagnostics, body repair/paint refinishing, suspension, interior and complete restoration.
ST Suspensions ST XA (adjustable dampers) For VW MK7 by Espada Motors
ST XA COILOVERS
For drivers wanting more than just ride height adjustment comes the ST XA coilover. Developed alongside KW Automotive the ST XA allows individual adjustment of the damping to suit just about all your driving needs!
Perfect for sporty driving
ST XA coilovers feature KW damping technology which allows the suspension to be made either stiffer or softer depending on the driving conditions. This damping adjustment is made on the upper end of the chromed piston rod allowing the setup to be changed almost instantly. If the rebound force is increased, the car will drive with even more track stability and further reduced bodyroll. If the rebound force is decreased, the car will feel more comfortable when on the move. Any vehicle fitted with ST XA coilovers will act much more agile and sporty compared to standard.
Easy lowering adjustment
Like all ST coilovers the lowering adjustment is made via a continuous thread on the galvanized strut. This even allows the lowering to be made even when the kit is installed by turning the spring plate higher or lower! NOTE: The lowering of each vehicle differs greatly with ST XA coilovers due to the type of construction. For example, older vehicles such as the Honda Civic (EJ9) can be lowered between 40-75mm with ST XA coilovers, while newer models such as the Audi S3 (8P) can be lowered between 10-40mm due to being much lower from the factory.
KW Engineering: Exclusive for ST suspension
The high-quality ST XA coilover is based on the twin-tube damping principle of low friction combined with pressure-resistant damper housings. Manufactured directly at KW, a mono block guide and seal package reduces the friction of the damper as well as protecting it against corrosion and dirt. Each galvanized strut is sealed multiple times to ensure maximum longevity in ALL weather conditions.
•External damper adjustment
•Latest damping technology for maximum longevity
•Reduced system friction for effective damping adjustment
•Individual lowering within the TÜV-tested adjustment range
•Front and rear axle (when possible) with thread adjustment
•Galvanized coilover struts with additional coating for an optimized corrosion protection
•Complete solution with adjustable spring plate, race spring system and bumpers with dust protection
Price: RM 6280.00
Warranty: 2 years
We do provide installation
Please call for other models n stock availability.
Please drive your car to 11, Jalan PJS 7/19 46150 Bandar Sunway, Selangor for pricing & quotations. For any enquiries please feel free to call me at 0123030249.
Hope to hear from you guys soon. Thanks for the support in advance guys.
Thank You.
Contact no: 0123030249
Address: No 11, Jalan PJS 7/19 46150 Bandar Sunway, Selangor.
ST Suspensions ST XTA (adjustable dampers + Unibal top mounts) For VW MK7
ST Suspensions ST XTA (adjustable dampers + Unibal top mounts) For VW MK7 by Espada Motors
ST XTA COILOVERS
For those who demand the absolute best performance comes the ST XTA coilover. The full driving behaviour of your car can be adjusted using KW damper technology along with an adjustable aluminium uniball top mount for fine-tuning of the camber and caster!
Performance driving in mind
ST XTA coilovers feature KW damping technology which allows the suspension to be made either stiffer or softer depending on the driving conditions. This damping adjustment is made on the upper end of the chromed piston rod allowing the setup to be changed almost instantly. If the rebound force is increased, the car will drive with even more track stability and further reduced bodyroll. If the rebound force is decreased, the car will feel more comfortable when on the move. For increased performance, the ST XTA features an aluminium adjustable topmount allowing the camber and caster to be adjusted depending on your driving needs or vehicle setup.
Like all ST coilovers the lowering adjustment is made via a continuous thread on the galvanized strut. This even allows the lowering to be made even when the kit is installed by turning the spring plate higher or lower! NOTE: The lowering of each vehicle differs greatly with ST XTA coilovers due to the type of construction. For example, older vehicles such as the Honda Civic (EJ9) can be lowered between 40-75mm with ST XTA coilovers, while newer models such as the Audi S3 (8P) can be lowered between 10-40mm due to being much lower from the factory.
The high-quality ST XTA coilover is based on the twin-tube damping principle of low friction combined with pressure-resistant damper housings. Manufactured directly at KW, a mono block guide and seal package reduces the friction of the damper as well as protecting it against corrosion and dirt. Each galvanized strut is sealed multiple times to ensure maximum longevity in ALL weather conditions.
•Aluminium adjustable uniball top mounts (when possible)
•Scaled camber adjustment (optionally also caster)
•Externally adjustable damping
Price: RM 6880.00
Warranty: 2 years
Thank You.
ST Suspensions ST X (fixed damper setting) For VW MK6 & Scirocco by Espada Motors
Need to get low? ST coilovers feature a continuous thread construction for height adjustment from moderate to eXtreme! Each coilover is manufactured by KW Automotive and their expertise and know how ensures maximum quality and fantastic driving dynamics. Once installed, the ST X coilover can be easily adjusted using a polyamide ring on the galvanized, multiple-sealed strut. Adjustment is different for each car, but typically you can expect between 35 and 65mm of lowering on both the front and rear axles. For lowered cars as standard (such as the BMW E9x 3-series) the ST X coilover features a range of 30 to 60mm (front axle) and 25-55mm (rear axle).
Improved driving dynamics and handling
Designed in conjunction with KW Germany, ST X coilovers deliver a sporty handling by reducing the car’s bodyroll during compression as well as improving agility when driving fast. The high-quality production of each ST X coilover includes a low-friction and pressure resistant housing alongside a chrome-plated piston rod for maximum longevity. A mono block guide and ST seal package ensures the twin-tube dampers remain free of dirt particles in all weather conditions.
Lowering with St style: the ST X coilovers
•Front and rear axle thread adjustment (when possible)
•Galvanized coilover struts with additional coating for optimized corrosion protection
•Powerful twin-tube dampers with high-quality components for maximum longevity
Price: RM 5800.00
Warranty: 2 years
Thank You.
ST Suspensions ST XA (adjustable dampers) For VW MK6 & Scirocco by Espada Motors
ST XA COILOVERS
Price: RM 6400.00
Warranty: 2 years
Thank You.
ST Suspensions ST XTA(adjustable dampers+Unibal top mounts) VW MK6 & Scirocco
ST Suspensions ST XTA (adjustable dampers + Unibal top mounts) For VW MK6 & Scirocco by Espada Motors
ST XTA COILOVERS
Price: RM 6980.00
Warranty: 2 years
Thank You.
